Trans filter change on '93 vert
Old Nov 6, 2014 | 02:00 PM
maddogwyatt's Avatar
maddogwyatt
Default Trans filter change on '93 vert
I'm about to change the fluid and filter in my auto trans. Had a look today, but wasn't sure if I need to remove the "X" brace to get enough clearance to get the pan out?
I need to buy a FSM instead of my Haynes - it's useless!!
Old Nov 7, 2014 | 12:19 AM
Cliff Harris's Avatar
Cliff Harris
I have a coupe, so I don't have firsthand knowledge of the problem. That said...
The filter sits on the bottom of the pan. You need to drop the pan far enough to clear the filter, which hangs down about 4" or so. I doubt you have that much clearance without removing the X brace. I suppose it might be possible to work the pan around the X brace, but I think you'll spill a lot of ATF in the process.
Old Nov 7, 2014 | 05:54 AM
enventr's Avatar
enventr
I dropped my pan on the 95 it was a pita. When I put the brace back on it was slightly too close to exhaust and it made a vibration noise had to readjust brace by a hair
Old Nov 7, 2014 | 01:30 PM
maddogwyatt
Thanks guys. it sounds like we need to remove the "X" brace for definite then. Thanks very much for your help.
Old Nov 7, 2014 | 08:32 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
Removing the brace would take less time than trying to work around it. When the car if up on the jack-stands, slide a floor jack under the enter of the brace, and then pull the bolts, including the 4 smaller ones about a foot behind the 'X'. Then just pull the brace out while it is still on the floor jack.
If you don't want a big mess with spilled tranny fluid, suction most of out through the dipstick tube, and then pull the pan.
Old Nov 8, 2014 | 01:49 PM
maddogwyatt
Thanks -that's more or less what we thought, particularly siphoning some fluid out first. Haynes was virtually useless on this one....surprise, surprise!! Thanks again.
To Trans filter change on '93 vert
