What could this mean
Old Nov 9, 2014 | 02:07 PM
Mmrseed's Avatar
Mmrseed
7th Gear
Default What could this mean
Just got an innova 3120 obd 1&2 reader for my 93 vette to try and figure out what's wrong. The reader just keeps saying it can't connect to the computer. The ignition is on but not running and I hear the reader turn the computer on but no communication
Old Nov 9, 2014 | 02:18 PM
Dr_Shakalu's Avatar
Dr_Shakalu
Take a look at the connector plug that plugs into the car. Check to see if any of the pins in the connector plug are bent. I had the exact same thing happen and I saw that one of the pins inside the plug was bent from connecting it. Straighten out the pin or pins and make sure that you carefully plug it into the car so none of the pins will get bent.
Old Nov 9, 2014 | 02:23 PM
Mmrseed's Avatar
Mmrseed
7th Gear
I checked. Nothing bent and it's a brand new reader and connector. I tried the reader on my other cars (obd2 tho) and it works so it's not a vaulter handheld
Old Nov 9, 2014 | 02:36 PM
Mmrseed's Avatar
Mmrseed
7th Gear
Ok so it looks like blown fuse can cause obd comm failure. Anyone know what fuse is responsible for allowing the obd port to connect to the ecu?
Old Nov 9, 2014 | 03:58 PM
Mmrseed's Avatar
Mmrseed
7th Gear
Ok now I'm really irritated. It seems a few fuses (glovebox not under hood) were mixed up from whoever had it before and that was one reason I had a dash buzz whenever the hatch sensor was depressed and the interior lights stayed on. The fuses are correct now but now my car won't start. Could electronic gremlins be so bad that incorrect fuse placement helps the car start? I would put it back if I remembered where the mixed up fuses went. Help
Old Nov 9, 2014 | 07:03 PM
Dr_Shakalu's Avatar
Dr_Shakalu
Do you mean it doesn't crank or does crank but no start?
Old Nov 9, 2014 | 07:43 PM
Mmrseed's Avatar
Mmrseed
7th Gear
Wow...ok my battery was DEAD. Jumped it and tried to reread codes but no luck. The innova tech people said to try and use different model years and vin digits to access but no luck and the battery died again. Gonna change that and see if that helps. Wonder if a weak battery is the cause of all my other drivability issues......
Old Nov 10, 2014 | 03:09 AM
Cliff Harris's Avatar
Cliff Harris
Pull the error codes with the paperclip method:
http://corvettephotographs.com/c4vettes/codes.htm
Old Nov 10, 2014 | 10:48 AM
c4cruiser's Avatar
c4cruiser
This.
As far as the battery being dead or a low charge, recharge it!! What voltage are you seeing? Use a digital voltmeter to read the voltage at the battery terminals. Make sure everything is off; ignition OFF and key out, close the doors to allow the interior lights to go off and make sure the underhood lights are off.
A fully charged battery will show a voltage reading of something like 12.6 to 12.8 volts. A battery is considered discharged at 12.0v. Also with a good battery and the engine running, you should see voltage around 14.1 to 14.3 if the alternator is OK. After a few minutes of driving, voltage should drop back to something like 13.5 to 13.7v.
Old Nov 10, 2014 | 11:42 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Originally Posted by Mmrseed
Wow...ok my battery was DEAD. Jumped it and tried to reread codes but no luck.... and the battery died again
C4cruiser is right; get your battery situation under control, first. Get it properly, and fully charged.
SINCE your battery went DEAD, (at least twice now), you may not have any stored codes. When you remove power form the ECM, stored codes are erased.
I also agree w/the paper clip method.
To What could this mean
