Distributor cap & rotor
Old Nov 9, 2014 | 08:33 PM
gbarrett's Avatar
gbarrett
Default Distributor cap & rotor
I was doing a tune up on my 84 Vette, 80,000 miles. I swapped in the new dizzy cap & rotor, Accel brand. Everything started and ran fine, but I had a horrible noise in the radio. I put the original cap back on and radio is fine. Is Accel a bad brand or is there a better brand? I haven't done plugs yet, any recommendations?
Thanks for the info!
Old Nov 10, 2014 | 06:03 PM
Tom454's Avatar
Tom454
Did you use the factory coil in both cases?
Old Nov 10, 2014 | 08:44 PM
gbarrett's Avatar
gbarrett
Same coil both times. That does make me think about the coil spring conductor. I'm wondering if there might be some issue there. I'll swap them back out tomorrow and see.
Just seems weird. I've done this so many times and this issue is a first for me.
Old Nov 10, 2014 | 09:40 PM
Deepa's Avatar
Deepa
Does your new cap have the ground strap installed under the coil?
Old Nov 10, 2014 | 10:01 PM
gbarrett's Avatar
gbarrett
Yes, the strap was there. When I swap the caps tomorrow, I'll check the connection between the coil and the spring/brush to the rotor. I'm overlooking something. The car runs fine with the troublesome cap, it just creates a lot of radio noise.
Old Nov 12, 2014 | 07:43 AM
Tom454's Avatar
Tom454
I know it a PITA because I just had mine apart... but can you put the original parts back on to see if you still get the RFI?
Old Nov 15, 2014 | 03:03 AM
Joe C's Avatar
Joe C
FWIW - I've used accel caps and rotors on my 85 for at years, recently on my 90, and never ANY noise issues. can't see why an 84 would be any different - ????
Old Nov 16, 2014 | 02:01 AM
383vett's Avatar
383vett
The only cap and rotor brand I use on my 84 is Accel and have never had a problem.
Old Dec 11, 2014 | 07:27 PM
gbarrett's Avatar
gbarrett
Default Finally found the problem!
I waited until dark and took the dizzy cover off. There it was - the coil is arcing to the ground frame. I've already ordered a replacement.
Thanks for the input!
To Distributor cap & rotor
