Ca. Smog High Nox
Old Nov 10, 2014 | 05:31 PM
Dr_Shakalu's Avatar
Dr_Shakalu
Default Ca. Smog High Nox
Hi everyone. Well, just failed smog check for the first time. All the numbers look great except the NOX at 15mph. CO2=0.0 @ 15 & 25 mph, HC=1 @15 & 25 mph and CO=0.0 @ 15 & 25 mph. This is the results for the NOX which I failed. NOX = 612 @ 15mph FAIL and NOX=705 @ 25 mph barely pass. No codes but I'm thinking it's either egr valve, egr solenoid or the passages might have some carbon build up. The egr valve and solenoid were changed 2 years ago. I will check both the valve and solenoid but I want to clean the passages also. What's the best way to clean the passages and could there be something else I'm missing?
Old Nov 10, 2014 | 07:58 PM
GKK's Avatar
GKK
What year and is the exhaust all stock?...
Old Nov 10, 2014 | 08:32 PM
Dr_Shakalu's Avatar
Dr_Shakalu
It's a 96 coupe auto. Stock everything but with mufflers deleted. Same set up.since I got the car 4 years ago.
Old Nov 10, 2014 | 09:00 PM
pkincy's Avatar
pkincy
An owner of a local STAR smog station (individually owned but qualified by California to do smogs of high emissions vehicles) told me that the first thing to do when faced with a near pass, but fail condition is to replace the Oxygen Sensors. If you have the same one wire AFS 21 my 93 has they are $14 each and only need a 7/8ths inch wrench to replace although special sensor sockets are available.
After that you might datalog the car to see that it is in fact controlling near the Stoich Point and not running particularly lean or particilarly rich. If lean it robs the exhaust of oxygen needed for the converter to reduce the NOx.
After all that you can replace the converters. I did it back in the day when you could find a low mileage C4 in the junkyard with really good cats. Don't know about that supply these days.
Perry
Old Nov 10, 2014 | 09:30 PM
Dr_Shakalu's Avatar
Dr_Shakalu
Perry
I was told that my cats were doing it's job by the numbers I got from the test. Do you think it doesn't have anything to do with the egr system?
Old Nov 10, 2014 | 10:57 PM
pkincy's Avatar
pkincy
The fact that they were allowing oxidation take place certainly would indicate that. But the NOx removal is a reduction step and takes even more oxygen. However I would not redo the cats lightly. My point was that at $28 and shipping, 2 sensors are a trivial thing. I don't even know if that recommendation was a good one, but the guy had been owning a smog station in Ca a long time, so I have decided to take his advice and ordered 4 sensors for both my 93s.
I can't mention my vendor at that price as they don't pay this forum, but it was a simple parts search on Google for the AFS 21 one wire sensors
Old Nov 10, 2014 | 11:04 PM
Dr_Shakalu's Avatar
Dr_Shakalu
Thanks for the info. I don't know if any of the sensors have ever been replaced but I think for the price, I will change them anyways.
Old Nov 10, 2014 | 11:18 PM
drive it's Avatar
drive it
Odds are your egr solenoid is not working. (been there/done that!)
Pull it off and actually test it.
I applied vacuum to the in port (with brake bleeder) and a vacuum gauge to the out port; and applied ground and power to the leads to really test it.
I went thru 3 new that all had various types of shorts/malfunctions before I found a used one that actually worked.
Old Nov 10, 2014 | 11:31 PM
Dr_Shakalu's Avatar
Dr_Shakalu
I just picked up a new egr valve but I will vacuum test the old one first before installing. Price for the new egr valve was about $70 so it wasn"t too bad. Easy to swap out so it's what I'm going to do first.
Old Nov 11, 2014 | 02:10 AM
drive it's Avatar
drive it
It's the solenoid that controls the vacuum to the egr that I have found the main problems with.
Old Nov 11, 2014 | 05:51 PM
pkincy's Avatar
pkincy
Does you state not check the operation of the EGR valve? California does, I believe.
Old Nov 11, 2014 | 06:33 PM
Dr_Shakalu's Avatar
Dr_Shakalu
Yeah, I'm in San Francisco, California. I just changed the egr valve and the old one's diaphragm seemed a little stiff but I'm beginning to think it might also be the solenoid. I have the solenoid ordered and should get here in a couple of days. Decided to change the egr valve, solenoid and vacuum hoses because the cost for all parts are under $80 and that way I can cover all the bases.
Old Nov 12, 2014 | 09:18 AM
tbirdsps's Avatar
tbirdsps
High NOX at low speed usually indicates lean running. The EGR won't open or begin opening until about 1800 - 2000 rpm. You ought to look at the 02 sensors. It's fairly easy to test the EGR.
Old Nov 12, 2014 | 01:36 PM
drive it's Avatar
drive it
Actually if you look at the code in the bins egr begins at 1200 rpm.
In Cali they run it at 15mph and 25mph loaded on a dyno, so rpms are usually 1500 to 1800 rpm depending on your gearing.
Kali smog is a pia-if you burn your own proms it makes it easier-really necessary with mods.
And yes if too lean the nox goes up.
You should buy a scan tool that will show live data also, not just codes-see what blms are. You'll probably wonder how you ever got along without the scan tool after you have it a while!
Old Nov 12, 2014 | 03:11 PM
Dr_Shakalu's Avatar
Dr_Shakalu
I actually do have an OBDII scanner that I use when the engine light goes on. I know my scanner does show live data but I don't know what I'm looking for and exactly how to use it.
To Ca. Smog High Nox
