Missing bracket. Got a picture?
Old Nov 11, 2014 | 09:36 AM
Mike in Boston's Avatar
Mike in Boston
Default Missing bracket. Got a picture?
There seems to be a bracket that bolts to the bock to keep the coolant temp wire away from the exhaust manifold on the passenger side head.
Does anyone have a picture of what it looks like?
I looked through my FSM but couldn't find it.
This is for a 91.
Old Nov 11, 2014 | 12:07 PM
don hall's Avatar
don hall
Not sure if this photo will help....... from a '92 LT1. The sensor hole
is below the aluminum pipe curve.... see threads. There is no bracket
to protect the analog sensor wire. Your L98 may be different.
Old Nov 11, 2014 | 01:03 PM
Mike in Boston
Interesting. Maybe there isn't a bracket there.
Thanks!
Old Nov 12, 2014 | 02:58 AM
Cliff Harris's Avatar
Cliff Harris
This is what the CTS on my '86 looks like:
Old Nov 12, 2014 | 06:23 AM
HlhnEast's Avatar
HlhnEast
My CTS connector is all melted. It is my understanding that the sensor in Cliffs pic is for the secondary fan on my '85 which I do not have so I have never thought about fixing it. The CTS for the ECM is on the front of the intake manifold and the gauge CTS is on the Lside between 1 and 3 cylinder. Am I correct here?
Old Nov 12, 2014 | 03:58 PM
Mike in Boston
I'm not sure if the sensor in Cliffs post is for the secondary fan or for the temp gauge but it is definitely then one I'm interested in.
Looking at my old block it looks like I had a bolt holding a bracket to the block that kept the wire away from the exhaust manifold. I have no idea what it looks like so trying to find it in the big old box of parts was unsuccessful assuming I even have it.
I made something to do the job but it bugs me when I can't find the original part 😀
Old Nov 13, 2014 | 04:46 AM
WVZR-1's Avatar
WVZR-1
It's very likely that originally there was a conduit clip that was used to secure the harness for mostly assembly line convenience. They could be clipped to or taped to wire or wire bundles.
This is most of the popular Delphi products that were used:
https://www.powerandsignal.com/docs/...&%20Clamps.pdf
Old Nov 14, 2014 | 01:19 PM
Tom454's Avatar
Tom454
Just checked my 87 and there is a bracket/support for that wire.
Old Nov 15, 2014 | 07:28 AM
Mike in Boston
The mystery continues!
Old Nov 15, 2014 | 08:14 AM
Tom454's Avatar
Tom454
FWIW... the connector on mine came off the spade, slid down the wire, and was also melted, and was stuck to the exhaust manifold.
Old Nov 15, 2014 | 02:00 PM
Mike in Boston
I picked up a replacement connector at rock auto for 31 cents.
Search for part number 6288704.
To Missing bracket. Got a picture?
