Shift points
Old Aug 2, 2002 | 02:14 PM
Bradley3's Avatar
Bradley3
Default Shift points
I just had my rear end changed from 2.59 to 3.54 as well as a shift kit installed.
now it seems like my 1-2 shift is a little late. If I'm on it it'll go up to redline and sit there for a second or two before shifting down. It seems like it should be shifting quicker.
Is this normal after the work I've had done, or should I be concerned?
Old Aug 2, 2002 | 02:27 PM
93 ragtop's Avatar
93 ragtop
Default Re: Shift points (Bradley3)
I put a camera in mine and set it at the dash. My tach went to 6000 on 1-2 and 5700 or 5800 on the 2-3 shift. It should be hitting the rev limiter but it dosnt. Bottom line is my tach is off. I am in the process of locating a laptop to take to the track. With the craig moates program to see what it really is doing. If yours isnt falling on its face before it shifts, ill bet its the tach is off on yours as well.
Old Aug 2, 2002 | 02:35 PM
scorp508's Avatar
scorp508
A lousy tach is a standard item on Corvettes. :) When I shift at what looks like 5800 in 1st, it is 6250.
Old Aug 2, 2002 | 02:43 PM
93 ragtop's Avatar
93 ragtop
Default Re: (scorp508)
hey scorp, how did you determine how much your tach was off?
Old Aug 2, 2002 | 02:52 PM
scorp508's Avatar
scorp508
Default Re: (Red 86 4+3)
I hooked up a laptop and Diacom.
Old Aug 2, 2002 | 07:50 PM
dscottr's Avatar
dscottr
Bradley, I have got the same problem. If you have the 700 r 4 B&M makes a governor kit to adjust the shift points. What year is your vette? If you have a 94 or newer the power programmer can adjust shift points. If not the tranny has to be pulled. Or you can do what I am doing and install the hot cam and raise the rev limiter to 6,400 rpm
Old Aug 2, 2002 | 07:58 PM
dppeaden's Avatar
dppeaden
Scorp - Took the guess work right out of that one. :D
Old Aug 2, 2002 | 08:17 PM
scorp508's Avatar
scorp508
Yep. :) As you can see in this my throttle position sensor is at 0.64 momentarily (foot off gas) to shift. My dash said 5800 when I did this.
1st and 2nd the tach is basically useless.
To Shift points
