Still stumped on acceleration lag..
Old Nov 12, 2014 | 06:19 PM
Mike1985's Avatar
Mike1985
Default Still stumped on acceleration lag..
So I've tried to do my timing, but I can't find the marks for the life of me. Still haven't tried that white out trick though...but I just finished doing a tune up yesterday and was hoping that it would somehow help the problem I've been having. Ever since I baught my 85 months ago it's always had an acceleration lag to it. When I'm driving (even at a low speed like 20 mph) and I give it a decent amount of gas, the rpm will raise but it will take a second to put the power to the wheels...still stumped on what it could be...thanks for any help again guys appreciate all of it!
Old Nov 12, 2014 | 06:33 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Sounds like a typical automatic transmission down shifting...then going, to me. If the RPM's go up right away, doesn't sound like the motor is the problem.
What happens if you put the shifter in "low"/1 (1st gear) run it up to, say, 2000 RPM, then punch it?
Old Nov 12, 2014 | 06:48 PM
Mike1985's Avatar
Mike1985
I'm not able to do that because the leather on the shifter clumps up when I try to put it into 1st low so it goesnt go all the way back...would putting it in low drive be the same thing?
Old Nov 12, 2014 | 07:57 PM
THE 383 admiral's Avatar
THE 383 admiral
Remove the leather boot. Any codes? Is the detent cable set properly
Any transmission slippage? low trans fluid?
Old Nov 12, 2014 | 10:08 PM
pcolt94's Avatar
pcolt94
Goodness, I have the same effect with my 94 going into the Low gear. Found out when the leather boot is off all works great locking into proper positions. I believe the leather is just getting stiff as our cars age and due to sun or heat. It's not a problem for me as I do have the [D] and the next two lower notches. I don’t race and it just fine for my use.
A new boot might fix that problem if you wanted like new operation.
Sounds like on an 85 the clutches might be slipping.
Does it have lock up on the torque converter? Then try the test at 50 mph and see if there is slippage.
Old Nov 13, 2014 | 01:32 AM
Cliff Harris's Avatar
Cliff Harris
Did you open the EST connector (tan wire with black stripe) next to the windshield wiper motor? If you don't then the ECM will put in 20° of advance and you will not be able to see the timing mark.
Did you attach the timing light to #1 spark plug wire? It's fairly easy to get it on #3 if you're not paying attention.
If the above fails to resolve your issue then it's possible that the outer ring of the harmonic balancer has shifted.
Old Nov 13, 2014 | 06:24 AM
Mike1985's Avatar
Mike1985
No I haven't disconnected the est wire I figured that was just to change it...I'll try again today...
Old Nov 13, 2014 | 06:25 AM
Mike1985's Avatar
Mike1985
Slippage on what exactly? Sorry still kind of a newbie LOL
Old Nov 13, 2014 | 06:26 AM
Mike1985's Avatar
Mike1985
Changed trans fluid the other day so I know that's full
Old Nov 13, 2014 | 12:44 PM
tunedport85inject's Avatar
tunedport85inject
Hey if you don't disconnect the est connector then it's obvious that you don't see the mark in the balancer,it's 20 and more degrees up in the not visible portion of balancer....
Alberto-Italy
Old Nov 13, 2014 | 01:54 PM
don hall's Avatar
don hall
Happened to me, so just a humble suggestion.........
Check the accelerator cable from the pedal to the cable end in the
engine bay for out-of-adjustment. Any slop will cause lag.
http://www.corvetteamerica.com/cf/di...ategoryid=X805
Old Nov 13, 2014 | 02:06 PM
Mike1985's Avatar
Mike1985
Tested this about 10 times today in D, it happened twice but then didn't do it the other times..
Old Nov 13, 2014 | 02:20 PM
ch@0s's Avatar
ch@0s
Sound normal to me, when I step on the gas it takes a second before my tires light up.
Old Nov 13, 2014 | 09:13 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Right....but the problem there is that the trans can and will likely down shift from "D" (3rd gear), down to second, or even first, depending on your road speed.
I suggested putting it in 1st gear, since there is no down shifting from first. If there was a delay in first, it would have to be your engine. In any gear higher than first, there will likely be a delay as the trans figures out which gear to shift to, executes the shift and then engages the clutches.
Chaos' car takes a second b/c he has that slow soggy e-throttle.
Old Nov 13, 2014 | 09:52 PM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
hey wanted to chime in here. if your boot is hard like mine, take the bezel off, u can either leave the boot on bezel like i did or remove, grab some "neets foot" oil from a leather tack shop, and use a brush or sponge or your hands and drench the inside of the boot. not the side you see when installed....the sueade side that is the backside of the leather. let it sit for a few days. it'll take a bit, but my leather soaked mine up like a sponge and i re applied a few times.
nice and supple now. and it was stiff as a board. there are a couple places that have cracks but u cant see them.
hope this helps somebody.....and yah.....of course a person could just buy a new boot but for some of us we need to put limited funds into other things.
ive been thinking this would work great on leather seats bug id have to get the leather off and apply from the inside out and seems like alot of work.
Old Nov 13, 2014 | 10:18 PM
Mike1985's Avatar
Mike1985
So if I'm understanding you correctly, it's relatively normal for that delay in the higher gears?
Old Nov 14, 2014 | 10:44 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
It's normal for the automatic transmission to have a delay, while it goes through an operation of shifting gears.
It's NOT normal for the engine to have a delay. '80's and '90's Corvette engines have incredibly good throttle response, so if the delay is your engine "doing nothing" for a few seconds after you punch it, that is not right. If the delay is the time it takes for your trans to shift, and the RPM to increase correspondingly, then that is normal.
My "test" that I've suggested it a way for you to isolate which it is; the engine, or the trans. W/the trans in first gear, it can't shift. There is no shifting and it would/should behave just like s stick shift car, in first gear. Get the car rolling in first gear, maybe 15 mph....hit the gas. Car should go as fast as you can get your foot to the floor.
To Still stumped on acceleration lag..
Old Nov 14, 2014 | 11:18 AM
ch@0s's Avatar
ch@0s
Bingo ..OP is this your first Automatic? The converter also has a stall built in, stock is somewhere from 1500-2000 IRC.Mine has a 3500RPM stall
Old Nov 14, 2014 | 01:49 PM
Mike1985's Avatar
Mike1985
Yes it is my first
Old Nov 19, 2014 | 08:19 PM
Mike1985's Avatar
Mike1985
Tried the 15 mph test today. Car took off beautify. So I guess all is normal! Thanks for all the help.!
