Cutting Out on 1-2 Shift When Hot
Old Aug 2, 2002 | 03:09 PM
HOWSER's Avatar
HOWSER
St. Jude Donor '09
Default Cutting Out on 1-2 Shift When Hot
Here is the symptom...And this is only when the motor is hot (220+).
Under WOT between the 1-2 shift the car starts to cuttout. It's kind of a sputter heard through the exhaust. I have installed new plugs, wires, fuel filter, and Opti. It never acts up when the motor is cold, cool, or just warm...just when it's real hot. Also, when I punch it from a roll, say 20, when the motor is hot like this it will also cuttout (pretty badly too) until it shifts to second, then it just takes off. I know air temp effects performance, it has been in the upper 90's here, but what would cause these symptoms during hot days?
It never does this between 2-3 or 3-4 shifts. I need to attempt to fix this since I'm planning on going with a 100 shot soon.
All comments are welcome. :cheers:
Eric
[Modified by HOWSER, 1:17 PM 8/2/2002]
Old Aug 2, 2002 | 07:46 PM
dscottr's Avatar
dscottr
Default Re: Cutting Out on 1-2 Shift When Hot (HOWSER)
You may be hitting the rev limiter before the 1-2 shift. on my 92 this happens at 5800 or 5850 rpm. If that is the case you may want to adjust your shift points.
Old Aug 3, 2002 | 12:15 PM
HOWSER's Avatar
HOWSER
St. Jude Donor '09
Default Re: Cutting Out on 1-2 Shift When Hot (dscottr)
This is something I had thought about...but why would heat be a factor in this? I would think that if this was the case it would do this at each 1-2 shift under WOT.
How do you go about adjusting the shift points?
Eric
Old Aug 4, 2002 | 08:38 AM
merrick's Avatar
merrick
Your rev limiter doesn't change with temp. You may want to check for a fuel pressure drop under the conditions you spoke of. Maybe a loose fuel pump pickup tube.
Old Aug 5, 2002 | 05:55 PM
dscottr's Avatar
dscottr
Default Re: Cutting Out on 1-2 Shift When Hot (merrick)
When my car is cool it shifts fine also, but then after the first run at the track it takes longer to shift and hits the rev. limiter. I figure it just takes a little longer to shift when the tranny is hot. I have been told you need to pull the tranny to adjust the governor on the 700 R 4, and that B&M makes a kit for this purpose, to raise or lower shift points. If you have a 4L60E tranny, you can program your ecm for different shift points.
Old Aug 7, 2002 | 02:31 AM
merrick's Avatar
merrick
Slow to shift, that makes sense. On a 700R4 the governor is on the driver's side under the round cover in the tail housing. You wouldn't have to pull the tranny.
Old Aug 7, 2002 | 02:34 AM
Togo's Avatar
Togo
i'm no mechanic, but i play one on TV :jester could also be a clogged CAT! :confused:
Old Aug 7, 2002 | 09:54 AM
HOWSER's Avatar
HOWSER
St. Jude Donor '09
Default Re: Cutting Out on 1-2 Shift When Hot (85_togo)
Funny! Now about the cats...they are gutted.
To Cutting Out on 1-2 Shift When Hot
