led question
Old Nov 17, 2014 | 07:26 PM
mike c4's Avatar
mike c4
Default led question
installed a led bulb in my license plate light bulb lights but takes about 6 seconds before it comes on is this normal have led in all the interior they come on right away thanks in advance for any responces
Old Nov 17, 2014 | 07:30 PM
whalepirot's Avatar
whalepirot
Originally Posted by mike c4
installed a led bulb in my license plate light bulb lights but takes about 6 seconds before it comes on is this normal have led in all the interior they come on right away thanks in advance for any responses
Not in my experience is it normal, but does it really matter, as long as it illuminates?
With that delay, it acts more like a CF.
Old Nov 18, 2014 | 01:15 AM
Cliff Harris's Avatar
Cliff Harris
You probably have a poor connection somewhere (corroded connector pin or light socket contact). LEDs use much less current than an incandescent bulb, which magnifies the problem.
Old Nov 18, 2014 | 01:31 PM
pcolt94's Avatar
pcolt94
I can understand your frustration to get it right. Take the bulb out and light it up externally with some clip leads and a 12 dc source. This way you can verify if the bulb is good or bad. If the bulb is good, then you can look to the car for an answer to the problem.
This way you won't spend time on the car if the bulb is the problem.
Old Nov 18, 2014 | 05:53 PM
mike c4's Avatar
mike c4
thanks for the responces im going to check it out this weekend if it warms up a little 20 degrees now too dame cold to look at it now
Old Mar 24, 2019 | 10:16 PM
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
The BCM tests the amperage constantly. This is why even with the delay-off resistor setup we were working on back in 2016 wouldn't work. I spoke with a former GM engineer who worked on programming the BCM for the C6 and because this is hard-coded there is no way around it. There has to be a specific amount of resistance for the computer to not trigger hyperflash.
To led question
