Need Expert 4+3 Help
Old Dec 3, 2014 | 10:27 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
The harmonic damper is an easy place to push/pull the crank.
You might try doing it by hand, before prying it.
Old Dec 3, 2014 | 11:55 AM
glava2876's Avatar
glava2876
Thanks!
Old Dec 5, 2014 | 06:36 PM
DUB's Avatar
DUB
Originally Posted by glava2876
Ok, I did not think that through and looking back it was not too bright.
I am going to Harbor Freight today to pick up a dial indicator.
Because I don't want to mess up again;
I have never checked the crank shaft run-out, but doing a search, I read that after setting up the dial indicator, I "pry" the crank back and forth.
It seems that the easiest access to the crank will be from underneath at the harmonic balancer?
Or is there a better place to pry it and a recommended method?
Thanks for your patience -I am definitely learning something new.
NO PROBLEM.
I might try to remove the access cover on the front of the bell-housing and measure off the flywheel. I would CAREFULLY pry at the harmonic balancer...but read if off the flywheel which may be a bit easier....due to not a lot of room to set up a dial indicator. and prying from underneath may give better access to pry it outwards.
DUB
