Throttle Position Sensor problems
Old Nov 28, 2014 | 03:33 AM
blackozvet's Avatar
blackozvet
Default Throttle Position Sensor problems
I was doing the IAC and throttle position sensor reset, chasing an idle problem.
When I tested the TPS thru its range when I got to just over half throttle and the meter was reading 1.99 volts, It suddenly went to 1. on the readout and didnt change all the way to full throttle.
I removed the TPS and checked it again, same result.
It is not showing any codes.
This would tie in with an issue i had recently at hillclimb, where the engine wouldnt run at 3/4 or more throttle, the engine would nose over and the knock sensor code would come on.
Has anyone experienced this ?
Is it a TPS problem, or a wiring problem ?
Old Nov 28, 2014 | 04:47 AM
C409's Avatar
C409
..... You should have 5.00 volts on the reference wire from the ECU ... If you have that , it would rule out the wiring ... make sure you check it between the A and C wires on the connector ... the ground feeds back to the ECU for TPS ......
Old Nov 28, 2014 | 06:46 AM
blackozvet's Avatar
blackozvet
good idea, I will check for 5 volts and earth, last time I checked they were ok, but that was over 6 months ago.
if the wiring is ok, then it must be the TPS.
Old Nov 29, 2014 | 12:48 AM
Cliff Harris's Avatar
Cliff Harris
It definitely sounds like your TPS is bad, though it could be a bad connection or wiring problem.
The ECM has a puilldown resistor inside it that makes the ECM think the TPS is at zero percent if it goes open. When you hit a dead spot in the TPS it will act as if you shut off the ignition.
Old Nov 30, 2014 | 05:18 PM
blackozvet's Avatar
blackozvet
i checked everything again, I have 5 volts at the sensor connection, and now the TPS is reading from .54 up to 4.5 volts at full throttle.
I have to confess I think I didnt have the correct setting on the test meter,
Looks like fuel surge is my problem, but will worry about that in the new year.
We had a cruise night Saturday, the idle is a bit better now, especially after lowering the fuel pressure and putting the vacuum line back on. Its also interesting to compare the reading on the dash tacho compared to the Autometer tacho, sometimes the same, sometimes quite different !
Old Nov 30, 2014 | 05:30 PM
WW7's Avatar
WW7
I have to confess I think I didnt have the correct setting on the test meter,Looks like fuel surge is my problem, but will worry about that in the new year.
It could be the meter was set wrong, or it could be an intermittent problem with the TPS...When my TPS was bad, it would read fine sometimes , other times it had a dead spot while advancing it from idle to WOT..I would keep an eye on it.....WW
Old Dec 1, 2014 | 08:18 AM
C409's Avatar
C409
..... You might want to tape a fuel pressure gauge to the windshield ... another thing to consider is quantity of fuel in the tank ... C4's are notorious for fuel slosh issues when running less than 1/2 tank ... this would be compounded by running uphill ...........
Old Dec 1, 2014 | 04:09 PM
blackozvet's Avatar
blackozvet
The regulator Im using has the gauge screwed into it, I would have to remove it and put a schraeder valve in to test, but that will have to wait, Im moving house right now.
at the hillclimb I started with 3/4 tank, and then a full tank, it actually ran its quickest time with the full tank, but I dont want to be dragging that much weight up the hill. There are no more meetings till next April, its now the summer cruising season here in Aus.
I will make a shroud for the fuel pump assembly and see how that goes in the new year.
To Throttle Position Sensor problems
