Any pointers on changing LT1 sparkplugs?
Old Aug 3, 2002 | 07:20 PM
GRNVNM93's Avatar
GRNVNM93
Default Any pointers on changing LT1 sparkplugs?
I've heard bad stories of changing sparkplugs. My neighbor took six hours changing them in his L98. Any advice will gladly accepted! Oh! And what type plugs do you recommend for a '93 LT1? or stay with the stock delcos? thanks you guys! :cheers:
Old Aug 3, 2002 | 07:23 PM
BrentDev's Avatar
BrentDev
Default Re: Any pointers on changing LT1 sparkplugs? (GRNVNM93)
Have lots of cold beer nearby......you have to take a LOT of breaks because it simply wears you out!!!!
I bet you can do a search of the archives.....lots of tips there. Unfortunately, I didnt read them when I did it.
One of the better ones I have heard is to remove the inner wheel liner/skirts. Supposedly that gives you some good access to some of them.
But the passenger side one all the way in the back! :mad That one will make you cuss!!!!! :cuss
Old Aug 3, 2002 | 07:29 PM
GRNVNM93's Avatar
GRNVNM93
Default Re: Any pointers on changing LT1 sparkplugs? (BrentDev)
Small world!!! that's the same plug that made my neighbor cuss!!! Darn #8 plug! (i think) :lol:
Old Aug 3, 2002 | 07:33 PM
STL94LT1's Avatar
STL94LT1
I used a spark plug socket and an open-end wrench for this one. Just slide the socket on and turn it with the open-end wrench, works like a charm.
Old Aug 3, 2002 | 08:20 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Default Re: Any pointers on changing LT1 sparkplugs? (STL94LT1)
I used a stubby 3/8" flex wrench with a 10" extension and socket slipped over the end of the stubby. Worked fine.
Old Aug 3, 2002 | 08:57 PM
JEFFT's Avatar
JEFFT
If u think the plugs are bad wait till u try the wires.Grrrrrrr
Old Aug 3, 2002 | 09:00 PM
Rich_01659's Avatar
Rich_01659
Default Re: Any pointers on changing LT1 sparkplugs? (Blue 92)
my advice is - if it is in your way - REMOVE IT - the hour you spend removing these 'things' will make your life Sooo much better when you start doing the plugs, same advice for wires, don't even start until you remove every componet that is in your way :)
Old Aug 3, 2002 | 11:58 PM
Oly's Avatar
Oly
It will make your life a whole lot simpler to do this... and have patience...... lots of it. Remember to use "neversieze" (anti-sieze or whatever the he** they call it) on the sparkplug threads and dielectric grease on the spark plug boots.... makes next time a lot better too.
Old Aug 4, 2002 | 12:10 AM
vette92_1's Avatar
vette92_1
One Tool that will come in handy for this project is a Sidewinder Rachet. But anyway look at it, its no fun.
Old Aug 4, 2002 | 04:05 AM
jkingsbury's Avatar
jkingsbury
I just finished doing the plugs on my LT4. Must have taken my 6 - 7 hours. Numbers 6 and 8 are the killers. They are hard to break loose due to the strict space limitations. Hard to put any muscle on them. Once I got a socket and a ratchet drive on them, I used a medium length of pipe as a breaker bar to break them loose. From that point on you can use the ratchet and switch to using your hand very soon. Putting them back in, I put the plug in the socket and started them very carefully. Since they were coated with anti-seize, they go in much easier than they come out, and you can use your hands a lot more.
I agree with the previous post which says to remove as much stuff as you reasonably can without doing something totally rash. I'm doing the wires next, and am totally freaked out about that before I have even started the job. Good luck. :seeya
Old Aug 4, 2002 | 11:22 PM
nickd's Avatar
nickd
Default Re: Any pointers on changing LT1 sparkplugs? (jkingsbury)
plugs are easy, it's the driver side wires that are a pain.
As far as new plugs go, I just put in NGk Tr55's. They seem to work fine and are only $2 each compared to $6-8 ea. for the Ac Delco's. The delco plugs I just pulled, which were only in the car for a year, many were already missing the pucks. I'll never use them again.
Old Aug 4, 2002 | 11:55 PM
mooncricket's Avatar
mooncricket
Default Re: Any pointers on changing LT1 sparkplugs? (nickd)
This is one of the reasons why I like my L98 better than my LT1. There is only one tough one on the L98, the rest are a snap. I took one look at the LT 1 and said the hell with it.
Old Aug 5, 2002 | 12:45 AM
ZBRA's Avatar
ZBRA
Default Re: Any pointers on changing LT1 sparkplugs? (mooncricket)
I suggest AC Delco Rapidfires.
BTW: The second generation Rapidfires are platinum and do have to be gapped!
And, I agree that the wires are harder than the plugs. I never tried to change my plugs before putting the long tubes on, so I don't know how hard they were originally. They aren't that bad now.
Old Aug 5, 2002 | 03:10 PM
Thud's Avatar
Thud
Default Re: Any pointers on changing LT1 sparkplugs? (ZBRA)
Wires are pretty easy, and only take a couple of hours.... after you've removed the water pump, and the entire accessory bracket. :smash:
Old Aug 5, 2002 | 11:18 PM
ZBRA's Avatar
ZBRA
Default Re: Any pointers on changing LT1 sparkplugs? (Thud)
I didn't remove the bracket, but I did have to move the p/s pump out of the way. This was of course after I had already pulled the alt and a/c compressor.
Old Aug 5, 2002 | 11:40 PM
ittlfly's Avatar
ittlfly
If you can get the car up on a gas station type lift, it makes life very easy when you do the wires. The drivers side is the worst but can be done from underneath without removing anything. I did mine in about an hour. If you can't get a lift then in that case, your're stuck with the top route.
Old Aug 5, 2002 | 11:57 PM
GlockLT4's Avatar
GlockLT4
pointer : figure out how to turn your body into rubber then change plugs. :jester
[Modified by Glock'94, 9:57 PM 8/5/2002]
To Any pointers on changing LT1 sparkplugs?
