Very quick easy question
Old Nov 29, 2014 | 03:03 PM
toochowed's Avatar
toochowed
Default Very quick easy question
Hey guys, brand new to the Corvette family (posted an intro).
Question, I have the bad LCD issue, and will send it in for fixing. In the mean time, I am using my Garmin as my speedo.
Question, is there a "low fuel" light on a 1991 vette? If so, that would help a lot as I do not know my gas level.
Thanks!
Old Nov 29, 2014 | 03:09 PM
WVZR-1's Avatar
WVZR-1
Thanks!
Have you at least checked the LCD fuse?
toochowed's Avatar
toochowed
I did yeah, it was fine, put a new one in for good measure and same thing. The screen just glows Orange and the tach is grossly inaccurate.
Old Nov 29, 2014 | 03:46 PM
don hall's Avatar
don hall
No audible alarm or light system....... fuel reserve is shown on the dash (fuel mode) as bars when the parking lights/head lights are on.
When the display is down to the last two bars, the message RESERVE will appear on the left of the gage. Without a working dash,
you are in trouble.
Warning.... don't let the fuel get too low as fuel cools the fuel pump.
Old Nov 29, 2014 | 03:58 PM
toochowed's Avatar
toochowed
you are in trouble.
a couple bangs to the dashboard turned it right back on!
Old Nov 29, 2014 | 04:06 PM
don hall's Avatar
don hall
[QUOTE=toochowed;1588371297]a couple bangs to the dashboard turned it right back on![/QUOTE]
I can understand your enthusiastic glee........ but, don't consider banging the dash as a permanent fix. If the dash stays illuminated,
that is great, but if the illumination is sporadic, time to search for
loose connections, broken wires, etc.
Good luck
Old Nov 29, 2014 | 04:07 PM
toochowed's Avatar
toochowed
[QUOTE=seabright;1588371340]
Good luck
Oh totally, just a fix for today so I know my gas amount. Ha. I will be sending it in for a refurb.
Old Nov 29, 2014 | 04:15 PM
don hall's Avatar
don hall
Just a humble suggestion..... if you don't own an OWNER'S MANUAL,
or FACTORY SERVICE MANUALS (FSM), check eBay for availability.
It is obvious that you have the mechanical/electrical skills to service your vette. Banging on the dash is where most of us started, and some never migrated.
Old Nov 29, 2014 | 04:16 PM
toochowed's Avatar
toochowed
Lol, yeah I got one on the way, picked one up from Ebay. I figured it was a good place to start to just know my current gas. Its being mailed in next week for a formal refurb!
Old Nov 29, 2014 | 05:09 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Just keep the tank full and you'll be fine. When in doubt, fill up.
Old Nov 30, 2014 | 02:22 AM
Cliff Harris's Avatar
Cliff Harris
When my fuel level sender wasn't working right I used the range number to determine how much fuel I had left.
Old Nov 30, 2014 | 10:55 AM
Red 91's Avatar
Red 91
You have to take the cluster out to send it in, why not inspect it before shipping. My 92 would do the same thing; smack the dash and came back on. I found a micro crack in one of the pins on the main cluster to harness connection. I desoldered and resolderd the pins and it now works. GOOD LUCK!
To Very quick easy question
