4+3 overdrive solenoid
Rich
eventually, once I get it sorted, I want to do the manual overdrive mod
There are tests that can be performed that take the relay out of the scenario...and see if ti will engage and disengage.
May need to call http://www.skspeed.com/
DUB
had the same problem with my 86 replaced the relay, no change
wires had come out of the plug and were bare but not touching each other yet
fixed that and no change
it was the wire on the bottom of the switch
disassemble, test switch, solder put everything back, works great
when tightening the nut that holds the switch to the bottom of the shifter i had it a little too far to the rear of the slot and it made the button rod bind up,
there is a happy middle spot for it to work just right that takes a bit to figure out
Good info here.
