Do I need more gear for my setup?
Old Nov 30, 2014 | 12:41 PM
ANTI VENOM's Avatar
ANTI VENOM
I'm not so sure you should have much "cam surge". I've run a similar cam but with a different trans and didn't have any surge. My friend ran a 230-236. Only time we noticed surge was when he slowed way down in first gear to go over speed bumps. If he didn't push in the clutch, then it would buck a bit. I do believe he was running a deeper gear though. That's been a while ago and many gear changes as well.
Old Nov 30, 2014 | 01:31 PM
volkswagens-for-life's Avatar
Originally Posted by Wheel Stander
My earlier motor was similar and I used 3.55s, but that was with an A4 and 2500 stall. YMMV
Thank you
Originally Posted by DanielRicany
Just curious, what did your car put down on the dyno?
I had to cancel the tune session due to a family vacation and never rescheduled
Originally Posted by tequilaboy
Look at your trap speed and dyno data. Select a gear/tire combination that will reach or exceed the hp peak at the expected trap speed in 4th gear.
Assuming you will trap in the vicinity of 107-110 mph with a 4500 rpm hp peak now (due to LTR intake), 3.07s should be about perfect with an 800-811 rev/mile tire.
If the car is slower, or if hp peak is greater than my assumption, you may benefit from a little more gear.
Cam surge will be worse with more gear.
I've only taken it down the 1/8th about 4x. Best 60' I could cut w/ my 25 year old tires was 2.6. I was right around 9.6 @ 77mph and had massive wheelspin in 1st and mid way through second. Babied the **** out of it launching. I haven't stuck the car on the dyno, but I can promise that w/ the cam my car isnt' even making power until 3k rpms and it pulls like a banshee to 6200 rpms in 1st.
Originally Posted by Vic'89
You have the stock TPI intake still ?
If so, gears will not help you at all. Save your money and purchase an intake.
Vic
Yes, ported upper and lower. You think an intake would be more beneficial than gears?
I notice it at the bottom of gears when trying to putt around. Sometimes I have to gear down and ride higher rpm's just to keep it drivable.
Old Nov 30, 2014 | 01:50 PM
383vett's Avatar
383vett
If you are really running 27 year old tires, I would chuck them asap before you end up in a ditch or hitting another car. You're living on borrowed time.
Old Nov 30, 2014 | 01:53 PM
Yep DOT # puts them as OEM. Didn't know this until AFTER I went to the track and my tires were a glazing mess. Working on some fatter tires this winter.
Old Nov 30, 2014 | 05:45 PM
856SPEED's Avatar
856SPEED
If you are still running the TPI intake and runners, your 3.08 (which is what I think you actually have rather than 3.07) gears are ideal; even with that cam you are not "pulling like a banshee" past 4500 RPM; it might "feel like it" but it's not. That dyno session will confirm it; you will see your torque fall off quick after 4000RPM and HP will soon follow around 4500-4700 RPM. Ported will help, but the system is designed for torque, not hp.
Keep your 3.08 gears unless you change to a different intake.
Old Nov 30, 2014 | 06:20 PM
Never heard of 3.08's stock in the l98 c4 only 3.07's? With the cam and heads I absolutely do not believe for one split second that my power is dropping off at 4500 rpm's. Agreed a dyno session would clear that up... but the tach is still climbing at 5500 rpms faster than it does below 3,000 rpms.
So my question is why do you say w/ stock TPI to keep stock gears, but w/ better intake get different gears???
Old Nov 30, 2014 | 06:32 PM
ANTI VENOM's Avatar
ANTI VENOM
I've only heard of 3.08 gears for the C4. The reason 856speed was saying that your power will drop off before 5k is due to the TPI intake and runners. Your cam and heads will probably have little effect in raising your usable RPM due to the restrictive nature of the TPI. Just my thoughts, but I'm not much of a TPI guy.
Old Nov 30, 2014 | 06:50 PM
It's a dana 44, 3.07 gear... you guys made me second guess myself for a second!
But why would the 3.0x gear be better for stock TPI than say, 3.54 gears?
Old Nov 30, 2014 | 07:49 PM
cv67's Avatar
cv67
St. Jude Donor '05
Tach may be climbing above 5k but power is dropping off
You need a stickier tire not so much a wider one. A wide low profile street tire will still give you traction issues. You could drop almost a second off your 60' and see a huge difference in your time slip car would be funner to drive.
Old Nov 30, 2014 | 08:09 PM
I'm almost willing to bet that stock size tires but something thats not 27 years old would even help me out... but if I'm gonna spend money on sticky tires it would be silly to not go a little wider too, just to ensure no traction issues lol.
Old Nov 30, 2014 | 08:38 PM
MavsAK's Avatar
MavsAK
Buy some new tires. You'll be amazed and in complete shock at how much faster your car is going to be. Even if those 27 year old tires, were some how brand new, the tech used to make them, is pathetic by modern tire standards. Even economy tires probably grip as good or better as your tires did new in the 1980s aside from their speed rating.
A good set of modern summer rubber, you'll pick up a crap ton of time.
Don't bother changing your gears yet.
Why on earth would you even consider getting new gears or further, when you're giving it all up at the tires in the first place?
I get it tires aren't cheap. But do it right or don't drive the car. If your rubber is over 5 years old imo, it's time to replace them. REGARDLESS of their treadwear.
Old Nov 30, 2014 | 09:55 PM
Good to know! So you dont think I need to go wider, that staying OEM size w/ NEW rubber will even make a difference?
Old Nov 30, 2014 | 11:06 PM
  #33
856SPEED's Avatar
856SPEED
yes, you do have a 3.07 ratio; my original in the 85 was a 3.08, my bad.
But as mentioned, you can't use your tach to gauge power levels by how fast the needle sweeps past 4500 RPM, trust me on that one.
I had the Edelbrock intake and runners before I switched to the miniram; it felt just a fast through the RPM range (with the same exact engine; no changes or even a change to the tune). But the dyno results and track results were night and day......see my mods listed below.....
when I ran the Edelbrock base and runners my RWHP maxed at 296rwhp and 380rwtrq; torque fell off dramatically at 4,000 RPM and power dropping like a lead balloon after 4500 RPM.
The miniram brought me up to roughly 350 rwhp (depending on what dyno) and 343rwtrq (depending on dyno); max power after the tune was at 6,000 RPM
1/4 mile trap speed improved from 108 to 112 ; BEFORE ANY TUNE;
same cam, heads, etc. ; just changed intakes from Edlebrock base/runners to miniram.
You want gears to keep you in your max power range- higher gears will put you in higher RPM levels past your peak power levels. 3.07 gears are great for a TPI car.
Old Nov 30, 2014 | 11:10 PM
  #34
856SPEED's Avatar
856SPEED
BTW; ANY 27 year old tires are BAD tires!
get rid of them; they have to be dry and hard has hell leading to safety concerns......
Old Nov 30, 2014 | 11:12 PM
  #35
Damn isn't that interesting. Good info man. So you basically had the same car as me (h/c/e) EXCEPT you had a better intake/runner setup and your power dropped after 4500? Hmmmm. You've got me wondering now. Damn I wish the track was opened because I'd drop my shift points to 5k and see how that reflects my 1/8 times (all poor launching aside). Is that about what you recommend I try out, 5k rpm shift points? Realistically I need to stop being a cheap *** and get on the dyno and get some real tune time put in... but I want ALL of the big mods done to the car before that point so I dont have to retune the setup.
The only reason I hesitate on 5k shift points is, the car doesn't wake up what-so-ever until 3k rpms... shifting at 5k is gonna put me below that 3k power band I feel.
Old Dec 1, 2014 | 12:08 PM
  #36
MavsAK's Avatar
MavsAK
For your setup, and the weight and size of the car, 275/40s are plenty big.
I'd stick with the stock size for this go around.
You're going to notice a world of difference, even if you went with ultra high performance all season rubber.
If you do go ultra performance all season, I recommend General Tire Gmaxs based on my personal experience, as well as Continental Extreme Contact DWS (recommend this one more).
Summer rubber, Conti Extreme Contact are amazing tires for the money spent. Then of course there's the big buck tires like the Michelin Pilot Super Sports, or Cup tires if your wallet is big enough, the traction is definitely there in spades with those.
Old Dec 1, 2014 | 07:23 PM
  #37
My stock size are 255/50/16's... was thinking about going to a 275-ish tire though. I've had great look w/ the conti DWS on other cars, but I haven't found them in a size that will fit my stock wheels and i'm NOT upgrading the stock wheels anytime soon.
I'm so damn tempted to take my car for a spin and keep the rpm's at 5k just to see how it reacts compared to 6k + shift points. Ugggg.
To Do I need more gear for my setup?
Old Dec 1, 2014 | 10:48 PM
  #38
Are you guys saying there is absolutely NO WAY a modded l98 can make power past 4500-5k rpm's w/ the stock kong runner intake installed?
Old Dec 2, 2014 | 12:01 AM
  #39
MavsAK's Avatar
MavsAK
5,000 is about the most you can expect really. You might be able to crank it out to 5500 rpm tops.
But that's with something like an AFR 220 head on it, which has a completely obscene flowrate.
Peak will always happen below 5k.
That's also assuming you have the edelbrock base, and at least edelbrock grade intake runners (they're better than the SLP runners.) and a ported plenum to go with it all.
The stocker even ported is never going to really get that much breath.
Here's a vid of the fastest TPI I've ever heard tale of with LTRs and NA. Notice how low he's shifting.
You can hear it. He's shifting right in the 4500 to 5,000 range.
As far as your tires go, even a new set of 255/50s ought to do you well compared to the junk you have on right now. I'd consider looking around for some wheels that can go to 275/40s though at the least. Should be pretty cheap to find given that alot of guys are going up to 315s these days on C4s it seems.
I'd have gone up that far myself, save I couldn't get the exact wheel I wanted in that width.
Old Dec 2, 2014 | 12:07 AM
  #40
Interesting. Thanks for the information. Definitely going to try my shifting points and see how it feels until I can get it on the dyno to know for sure.
