why does engine race?
Old Aug 3, 2002 | 11:05 PM
brdd's Avatar
brdd
From: Minnesota in the summer, Las Vegas in the winter
Default why does engine race?
I changed the air intake tubes on my L98....everything is back...started the motor and it races wide open. Throttle butterflies are closed and linkage is closed. Any help out there? Throttle cable slides fine when peddle is pushed. :cry
Old Aug 4, 2002 | 12:21 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: why does engine race? (brdd)
Check for vacuum leaks and check TPS voltage on the signal line.
Old Aug 4, 2002 | 07:34 AM
brdd's Avatar
brdd
I checked the vacuum lines. All seem to be connected. Voltage at the TPS terminal is .034 volts. I think that is low but I can't find any adjustment for that. Any further advice is welcomed. This is my first mechanical try under the hood of this corvette. It's been a tough one for me.
Old Aug 4, 2002 | 02:12 PM
brdd's Avatar
brdd
I had a car guy check this out and all is connected. I haven't a clue how to proceed. Do I have to completely tear this down and start over?
The first time took me 4 hours...... :cry
To why does engine race?
