93 with no injector pulse
So going on the assumption the opti is OK, look to the injector circuits. Make sure that is 12 volts on each pin of all the injectors. Voltage comes from 2 fuses one for each side. Both sides of each injector pins should have 12 volts on it (with engine not running). If this is OK, and there is spark the ECM could be the problem.
However the larger item that bothers me is that you cannot get any codes. This could be a communication problem with the CCM. And if the CCM is not working properly, then the signal (or bus handshake) pulse to turn on the ECM for the injectors might be missing. This is the FEDS part of the anti-thief system and does require the CCM to be healthy.
Make sure all CCM fuses are good and look for any corrosion. Any bad connection to inhibit the CCM from working will cause this problem.
I would check out other functions of the CCM like interior lights and other related functions.
But sounds like the ECM is gone as there is no communications from it. I seem to remember that the '93 ECM is difficult to find.
Good luck.
Thanks,
Ron
Use a piece of wire and short pin A to pin G on the diag. connector.
Turn the ignition On and look at the speedometer LCD.
Module 1 is the CCM
Module 4 is the ECM
If you get ERR for module 4 it indicates the CCM can not communicate
with the ECM.
If that happens, turn the ignition off and short pin A to pin B.
Turn the ignition On and look at the Service Engine Soon indicator.
It should blink 12 three times any codes three times and at the end of the sequence blink 12 again three times.
Example. 12 would be flash pause flash, flash long pause then 12 again.
If this fails something is wrong with the ECM and you need to verify 12 volts and ground at the ECM connectors.
Ron
Ron
Module 1 DTC 41 indicates the CCM can not communicate with the ECM and disables FEDS so there will be no injector pulsing.
Module 9 DTC 72 indicates the CCM can not communicate with the EBTCM computer located in the rear storage bin behind the drivers seat.
The CCM communicates with the EBTCM, C68 Programmer and the ECM by the serial bus. (serial bus is a piece of wire going to each module).
Disconnect the negative battery terminal.
Unplug the Brown connector at the ECM.
This removes the ECM from the serial bus.
Reconnect the negative battery terminal and short pin A to G.
Turn the ignition On. Verify if you still get a DTC 72 for Module 9.
If you don't, that indicates the ECM is causing the problem with the serial bus.
If you still get DTC 72 for Module 9.
Disconnect the negative battery cable. Remove the connector going to the EBTCM and reconnect the Brown ECM connector. Reconnect the battery and verify if Module 1 DTC 41 is gone. If it is the EBTCM is bad and the engine should start.
Ron
Ron
