Radio install in a 92
Old Dec 2, 2014 | 09:47 PM
482vranger's Avatar
482vranger
Default Radio install in a 92
I just installed a new Kenwood and totally bypassed the Bose. New speakers all around. Worked out fine, sounds great. One problem. I used the ignition wire going to climate control to bring on a relay for radio. Did not realize that it did not come on when key turned to aux. Sure don't want to tackle removing the tuner box. Does any one know where I can find a wire that comes on with key turned to aux. that is not to hard to get to. Thanks
Old Dec 2, 2014 | 11:33 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Right behind the head unit. Should be two multi pin plugs that used to plug into the old control head. One pin should be switched power and work on Accy and RAP.
