Wipers don't turn off
Old Dec 9, 2014 | 08:21 AM
Hairy W Bush's Avatar
Hairy W Bush
Default Wipers don't turn off
on my 95 corvette, Most of the time when I turn my wipers on, they stay at LO speed and refuse to turn off. This is the 3rd GM with this problem. It also gives me trouble turning it on to where I have to turn on the washer for them to work.
Old Dec 10, 2014 | 01:05 AM
Cliff Harris's Avatar
Cliff Harris
I had this problem when I first got my car and it was solved after the dealer replaced the wiper switch assembly under warranty.
I doubt that you could find a new wiper switch now, but anything is possible. The part number is 10045832, known as a switch. I found a couple on eBay and a few other places...
Old Dec 10, 2014 | 05:28 AM
HlhnEast's Avatar
HlhnEast
The wiper switch can be carefully opened up and cleaned. You might try that before you buy one.
Old Dec 10, 2014 | 11:11 PM
Hairy W Bush
the wiper switch can be taken apart? the stick in the column??
Old Dec 11, 2014 | 04:40 AM
HlhnEast's Avatar
HlhnEast
Oooopppps, sorry, I guess I didnt think about '90 and later. I wish my '85 had the stalk style wiper switch. Stupidest thing I have ever seen is putting the wiper switch on the door on the pre '90s
Old Dec 11, 2014 | 06:18 PM
eutu1984's Avatar
eutu1984
2021 C4 of the Year - Modified Finalist
The problem may be the contacts under the cover of the wiper motor itself, thats what happened to my 90. Remove the cover and clean the contacts and any of the connectors and plugs that plug into it. I just sprayed everything under the cover with deoxit.
https://www.google.com/shopping/prod...&ved=0CIsBELok
Old Dec 14, 2014 | 12:40 PM
Hairy W Bush
I just took off the cover. those 2 contacts on the side are clean. i wiped them anyway. i also sprayed both the connectors and nothing has changed.could it be a relay? if so where is it?
Old Dec 14, 2014 | 02:23 PM
Hairy W Bush
i scuffed the contacts just to be sure. nothing's changed. the wipers don't want to turn on and when they do they don't want to turn off. the delay doesn't work. (most of the time when i mess around with it anyway). it just wants to run on LO. this is aggravating. i tested the connector on the side and i guess it's working right when it's off, pulse, and high. the voltage switches to another terminal. cover or motor board or both?
Old Dec 15, 2014 | 02:50 AM
tlong's Avatar
tlong
Call Jason at Vette2Vette and get a board for the wiper motor. It's easy to change with 2 connectors and 3 screws. They fry under the hood. My washer would puke all its fluid and the wipers would stay on until I turned the ignition off. After the circuit board/cover swap it is back to wiper Nirvana.
A new one is only about a hundred bucks. Jason's are good to go for much cheaper.
Old Dec 19, 2014 | 05:07 PM
LannyL81's Avatar
LannyL81
My suggestion is to remove the wiper circuit board and reflow all the solder connections. Easy to do and might fix the problem.
Old Dec 19, 2014 | 07:12 PM
Hairy W Bush
I have a new cover on the way. expensive but i hope it fixes it. is that what you had to do?
Old Dec 22, 2014 | 11:09 PM
Hairy W Bush
I put the new cover on and thank God they work properly now. I looked closer at the old cover and noticed a couple solder joinds were worn down for some reason so I'll play with it another time.
In the mean time, where was a thin butyl seal on the cover. Anyone know where I can get some more? I have checked Lowe's, HD, advance and autozone.
Old Dec 23, 2014 | 11:41 AM
Joe C's Avatar
Joe C
hey hairy bush - not to go OT, but one question - does your mom drive a 93 arctic white (over black) coupe?
Old Dec 23, 2014 | 07:09 PM
Hairy W Bush
nah you must be thinking of someone else
Old Dec 24, 2014 | 02:40 PM
Joe C's Avatar
Joe C
so where in PC do you live? cypress knoll here....
Old Dec 24, 2014 | 04:39 PM
Hairy W Bush
indian trails. how do you know im in pc? it doesn't show up in my location
Old Dec 25, 2014 | 02:44 AM
Joe C's Avatar
Joe C
zipcode. I know from your posts, that you have a black 95 coupe - I've seen a black coupe with red GS hash marks running around town - is that you? BTW, Merry Christmas!
Old Dec 25, 2014 | 10:44 AM
Hairy W Bush
I've seen him too 1 day and we were on the same road. It's an older guy.
To Wipers don't turn off
