Got new engine installed now seems very tight
Kinda sucs but I'm hoping it is possible the valves are two tightly adjusted or too low or maybe there is some oil left in one of the cylinders.
There is no metal on metal sound but it gets real tight as if it is just an interference problem.
Tomorrow I'm going to take all the plugs out and turn it over and see if that changes anything. If not I'm going to back off the valve adjustment by 1/2 turn on all of them and see if that changes anything.
If none of that works buying borascope and taking a look inside.
Anything else I'm missing.
I definatly made sure the timing marks were aligned correctly.
It is not stopping because of bad timing misfire as it has not built up any fuel pressure yet just turned it over a couple of times.
NEW engine means that all parts that wear out have been replaced...correct????
SO...IF I read this correctly....The engine has NOT cranked and run yet....CORRECT???
Which is why I need to know the YEAR MODEL....it makes a difference. One type of engine has a distributor that can be adjuster...the other type you can not change the timing.
DID you PRIME the engine???? Once again..the type of engine matters on how this is done.
Hydraulic flat tappet lifters or roller lifters?????? Makes a difference.
There is a procedure to correctly adjust the lifters when it is on the engine stand.
I can not understand when you write about 'bad timing misfire' when it has not run yet due to no fuel pressure yet.....very confusing. the engine should be using an electric fuel pump.
Hopefully you do not have cylinders with a lot of oil in them. When it cranks and runs to break in the cam...it is going to be smoking like a factory.
I did not build it so I do not know what your ring gap was set at....or if it was checked if the cylinders were bored, etc.
Taking the plugs out is going to take out the 'compression factor'.
DUB
It is a 1986 vert.
I purchased a new block from summit and their stroker kit.
Everything is new crank, bearing, pistons, rings, PP, etc etc.
Used everything else from the original engine. TP, Injectors, etc.
Have 4 angle valve job completed
And yes it takes just about 60 Ft' lbs to turn it over less once it starts to turn.
Hydraulic lifters
stock new lifters, stock new rockers,
Thanks for your input so far. I have rebuilt several engines in the past my son and myself are doing this one.
If you just assumed it was right some of these things might have happened to you too. Hope not though..
The motor spun like crazy witht he plugs out and valves back about 3/4. I followed the directions for adjusting the rocker/valves.
Put it back together checked compression about 175 all cylinders. Put the the plugs in it and it feels tight but the starter can crank it over fine.
Going to go ahead and start it. I really hope the summit block and all the work we did is going to pay off not make us pay.
DID you PRIME the engine???? SO all parts are oiled and ready to go for cam break in procedure. You do prime the engine FIRST...don't you????
There is a procedure to correctly adjust the lifters when it is on the engine stand....so it all depends if you set the valves like in the manual COLD.
Now knowing that you have done engines before...it depends on what lube you used for the type of lifters....which that I have no clue that you have in the engine. Also how well the crank spun when you installed it.
****OPINION****
I am still baffled why you have oil in the cylinders...or put oil in them. I know people have their way of doing things...and some may think that squirting oil is fine in the cylinders....which I know many guys around me will do it for checking bad rings, compression test, etc. I guess what ever makes you happy.
Also....spinning the engine over and over and it not being primed is something I would not do. My opinion on that... When the engine is all lubed up and primed...I keep turning it over to a minimum. Crank it and get it to the RPMs for cam break in. And hopefully you are using 'break-in oil' when you do break it in...especially if it has flat tappet lifters.
DUB
Correct spark plugs for the heads will also not hit the valves. And depending on the piston deck height when you assembled it....and then checking the head gasket thickness. The squish pad on head and the piston clearance can be checked.
If the cold setting of the valves were properly preformed...you should not have had to back them off 3/4 of a turn.
One thing is not nonworking what parts were used......I know that one manufacturer a few years ago used an assembly lube while assembling eh lifters that if it was not thoroughly cleaned and the lifters pre-oiled....the lifters could stick and stay plunged and cause a problem.
Hope it cranks and works as you perfectly for you.
DUB
Wouldnt mess with valve adjustment or anything else just yet
Hydraulic lifters as stated before.
Just used oil to slide the pistons into the bores
Nothing is roller
Yes I primed it very well and we are are seeing 49 psi on oil pressure.
We also used grease etc for cam.
One thing I did not do is put hydraulic lifters into oil and soak them before I put them into the engine.
But I did prime it really well. But I must admit I adjusted the lifters prior to priming. I thought the hydraulic lifter internal spring was pushing back. Once you started to tighten the rocker arm ar TDC for that cylinder you spun the push rod till it stopped then you tightened one more full turn. I checked this over and over again before I did it and double checked it when done. But I backed off all of them by 3/4 turn and that seemed to help a lot.
It seems to act like a normal engine now with a lot of compression. Meaning as each piston gets close to TDC the starter slows slightly.
I appreciate your input, thanks.
Merry Christmas
****OPINION****
DUB
I know the factory lifters were flat tappet...but with a new block....it could have been one from a later year model where they used roller lifters.
Thanks for the reply....You seems to be ready to fire it up.
Merry Christmas to you also.
DUB
