I just got done replacing everything on my 1984 C4 chassis (stage 1 of my project). It's got rebuilt calipers, drilled and slotted discs, EBC pads, KYB shocks, Energy Suspension urathane bushings, Wagoner brake master cylinder, rebuilt booster, Moog U-joints, Moog front and rear wheel hubs, Moog upper and lower ball joints, Moog tie rod ends, rebuilt rack and pinion steering (pump too),and Raybestos brake hoses. I'm not sure if I missed anything....
My question is, Does anyone have a picture or diagram of the brake line connections at the master cylinder? I had everything taped and labeled when I took it all apart, but there was a bit of brake fluid in the lines and it migrated towards the tape and ate all the writing off.
I have searched for diagrams with no luck.
Thanks,
