Diff change
Old Dec 12, 2014 | 08:25 PM
Polo Vert's Avatar
Polo Vert
Default Diff change
I could have sworn I had seen a sticky or a thread somewhere about how to change out the center section of the differential but after searching I can't seem to find it. Has anyone else seen this and know where it is? Thanks!
Old Dec 12, 2014 | 10:31 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Remove exhaust
remove drive shaft
remove c-beam (support trans)
Remove toe rod ends and spring nuts/bolts
Remove two bolts/nut holding each lower control arm mount to diff.
Remove both axle shafts
Place jack under diff, remove both mounting bolts, lower diff out of car.
Old Dec 12, 2014 | 11:13 PM
jv9999's Avatar
jv9999
https://www.corvetteforum.com/forums...l-removal.html
http://www.thevettebarn.com/forums/c...s-learned.html
To Diff change
