computer
Old Dec 13, 2014 | 04:05 PM
barblarry93's Avatar
barblarry93
Default computer
Where is my ECM located on 1994 Corvette convertible?
Old Dec 13, 2014 | 04:38 PM
Kmcoldcars's Avatar
Kmcoldcars
If you mean the one in the engine compartment it is near the firewall on the drivers side. If you mean the radio ECM it is generally located behind the passenger seat in the storage compartment.
Old Dec 13, 2014 | 05:04 PM
barblarry93
the one that controls the engine
Old Dec 13, 2014 | 06:20 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Outlined in Red
Old Dec 13, 2014 | 10:40 PM
pcolt94's Avatar
pcolt94
Just to ask, what kind of problem are you having?
Also in the 94 (&95-96), the engine control computer terminology is called a PCM (Powertrain control module). Does the same thing basically but a very different part.
And just to keep things straight, the tuner module for the radio is called the CDM (behind the seat).
Old Dec 14, 2014 | 04:51 PM
barblarry93
I have a preformance chip coming from Jet. Want to know where it goes.
Old Dec 14, 2014 | 05:10 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
You should have a look at this vid...
Old Dec 14, 2014 | 06:07 PM
RollaMo-LT4
Your 1994 computer does not have a replaceable chip.
Anybody selling you a "chip" for that year is selling you some "snake oil" resister that only tricks the car into running slightly richer.
You will not see any performance gains.
Your '94 computer can be "tuned" with a programmer, although even that will need some engine mods to realize any performance gains.
Old Dec 14, 2014 | 06:33 PM
HlhnEast's Avatar
HlhnEast
Sorry but
Old Dec 15, 2014 | 12:19 AM
aDigitalPhantom's Avatar
aDigitalPhantom
Jet does not actually sell a chip (prom) for a 1994. They do have a handheld programmer, and a "module" that connects inline with one of the PCM connectors.
None of those is a substitute for a good tune, and there is not much point to get a tune for a mostly stock engine.
One of the problems here is that "CHIP" in many places is the term used for tune, handheld programmer, prom, and more.
Old Dec 15, 2014 | 03:04 PM
barblarry93
I have intalled a Magnaflow exhaust & K & N air filter
Old Dec 15, 2014 | 07:59 PM
pkincy's Avatar
pkincy
+2. The 94 uses a reprogrammable eeprom that is on the PCMs board. It can be erased and reprogrammed by Tuner Cat and LT1 Edit and other tuning software.
The chips stopped in 1993 and were actual 27C256 eproms (available sometimes at Fry's) that needed to be erased by strong UV light and then reprogrammed with a chip burner. That the newly burned chip would be placed in a CalPack that would then slip in the PCM a bit like memory does in a computer.
This is a calpack. The 27c256 chip is inside it.
Old Dec 15, 2014 | 10:48 PM
barblarry93
From what I understand the new module is placed just before the "computer", under the hood by the drivers side fender well, then the wiring harness plugs in the module.The new module requires modified exhaust,air intake, 91 octane fuel & 180 thermostat. Reportedly 20 hp increase.
Old Dec 16, 2014 | 10:05 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Did you watch the video that I posted? You won't be getting any 20 hp.
180 stat is stock, BTW.
Old Dec 16, 2014 | 10:11 AM
pkincy's Avatar
pkincy
Yes, these simply fool the computer by slightly changing a few of the sensor values.
I put an early Hypertech chip's .bin file in a file comparator and found 8 bits of information different than stock. Now that is on a 256,000 bit (or is it byte) chip that holds a file that is actually 4096 bits long. Not much of a change is why most of us don't think a lot of the changes.
Old Dec 16, 2014 | 10:25 AM
RollaMo-LT4
You'll be lucky if you don't lose 5 HP with one of those "resistors"
Old Dec 16, 2014 | 10:59 AM
WW7's Avatar
WW7
Why didn't you ask on here before purchasing something like this... These guys could of saved you some money....Can you cancel the order??
I would much rather get ribbed by these guys for asking about getting something like this , then actually getting it, and be stuck with a piece of crap that doesn't work......WW
To computer
Old Dec 16, 2014 | 12:01 PM
aDigitalPhantom
Or get a electronically erasable 27SF512, and skip the UV light.
Old Dec 16, 2014 | 04:02 PM
barblarry93
I certainly don't want to dispute your collective wisdom on this forum but for $188, I am going to try it. I just find it hard to believe that a reputable company like Jet could stay in business if their chips & modules didn't at least do some of what they claim they will do.You know the old saying from P T Barnum, "There's a sucker born every day" or was it,"A fool and his money soon part." Both may be appropriate in my case.
Thanks for the advice, I will let you know how this works out.
Old Dec 16, 2014 | 06:26 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Make sure that you get some good OBJECTIVE before and after data. SOTP is a worthless gauge.
