ASR/ABS help needed
Old Aug 5, 2002 | 01:35 PM
fsr402's Avatar
fsr402
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Default ASR/ABS help needed
I just put on some C5 wheels and I am running 275-40-17 in front and 285-40-18 in the rear. Now the service ASR and service ABS lights come on and stay on till I turn off the car. Every thing seems to be working right. Do you think that the different tire sizes are messing up the computer? :confused:
Old Aug 5, 2002 | 03:05 PM
Aaron71771's Avatar
Aaron71771
Default Re: ASR/ABS help needed (fsr402)
This is the standard GM brake fluid warning. Top off your brake fluid and make sure there are NO air bubbles in the system. Sometimes you have to top it off a few times before it works.
Old Aug 5, 2002 | 03:25 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
If the new tires are the same diameter as the old, there shouldn't be a problem.
If the diameters are different, then you would have the problem you describe.
Old Aug 5, 2002 | 03:52 PM
fsr402's Avatar
fsr402
St. Jude Donor '06
Default Re: ASR/ABS help needed (Mr Mojo)
the rears are taller then the fronts
Old Aug 5, 2002 | 04:53 PM
69mako's Avatar
69mako
Your wheels and tires have nothing to do with the ASR/ABS light coming on.
I had this problem last year :yesnod: There is a sensor in the brake fluid resv, if it sticks you will get the light coming on when you know nothing is wrong.
Take a small wrench or hammer and tap around the whole assmbly...this will loosen up the sensor and you should lose the light coming on. :yesnod:
Hope this helps, Larry :cool:
Old Aug 5, 2002 | 06:08 PM
MSR's Avatar
MSR
yes, the tire sizes will confuse the ABS system. dunno if the difference in your setup is enough to cause a warning light, but it might be.
as others have said, low fluid will also trigger the ABS light (dunno about the ASR, though). my vote is against that possibility if the lights coming on coincided with the wheel swap.
Old Aug 5, 2002 | 10:03 PM
dlmeyers's Avatar
dlmeyers
Default Re: ASR/ABS help needed (MSR)
The tire size is programmed for a particular ABS system. The ABS computer monitors each wheel speed and compares. If the speeds are not close to each other, it will trip the light and deactivate the system. With a change in wheel size, this will change the rotation speed of the reluctor. You can check this a couple ways. If you have a scanner with the ABS module, you can watch the individual wheel speeds and note any difference. 1 or 2 mph should be ok. Some ABS systems seem to tolerate a larger deviation. Don't know for sure what the allowance is. Bosch does not make software changes easy.
dlmeyers 90 coupe zf6 3 speed shocks
Old Aug 5, 2002 | 10:29 PM
fsr402's Avatar
fsr402
St. Jude Donor '06
Default Re: ASR/ABS help needed (dlmeyers)
Well it looks like I will just have to BURN these off and then put a little shorter set on.... thanks guys
To ASR/ABS help needed
