85 vette trans issues help
Old Dec 19, 2014 | 07:38 PM
johnnysixx80's Avatar
johnnysixx80
Default 85 vette trans issues help
Well driving on the freeway.and gunned.it and all the sudden felt like the car was in neutral let off gas seems alright then pulled off exit and only has second gear started the car in the morning all gears seem to be working but theres some terrible noise like sumthing broke in the trans then lost all gears again and only had second gear im sure this trans is toast now but I got 86 corvette tranny in good working order will this fit in the 85 ? My trans was rebuilt 2 years ago the 85 -trans and never had no prior warning of.it about to blew happened out of nowhere so 86 trans I have work in this 85 thanks for.ur help
Old Dec 19, 2014 | 09:13 PM
THE 383 admiral's Avatar
THE 383 admiral
Yes the 86 will fit. Every year GM had to improve the 700R4
Internal components.
Old Dec 19, 2014 | 09:15 PM
johnnysixx80
What u dnt understand is why would my trans take a **** with no prior warning never acted funny always had firm shifts and always shift on time
Old Dec 19, 2014 | 09:32 PM
THE 383 admiral
Dirty fluid, low fluid, over heated, TQ, VB wear, weak front pump, extreme driving such as burnouts. 700R4's have a long history of failing.
Old Dec 19, 2014 | 09:36 PM
johnnysixx80
Always change fluid since rebuilding it oh well ty
Old Dec 19, 2014 | 09:48 PM
johnnysixx80
Did the 86 trans get any changes internally
Old Dec 20, 2014 | 03:09 AM
Cliff Harris's Avatar
Cliff Harris
I don't think so. The big changes were in 1987 when they added the auxiliary valve body. There was an earlier change to the input shaft (30 splines vs. 27), but that happened in 1984 so it doesn't apply in your case.
Old Dec 20, 2014 | 03:12 AM
johnnysixx80
Thank.you for all.your replys just sucks what would be proper way to adjust tv cable press d button slider back and push pedal to.floor is.that right ?
Old Dec 20, 2014 | 07:05 PM
THE 383 admiral
Yes,
That is the correct adjustment.
Old Dec 20, 2014 | 07:54 PM
johnnysixx80
Yes,
Thanks guys I just found out my trans is not trans they cut the output shift down means jerkoff that rebuilt my trans kept my vette trans give me sum ******** trans with crappy cheap parts in it
Old Dec 21, 2014 | 02:32 AM
383vett's Avatar
383vett
My trannies have always broken without warning; planetary gears, sprag, input shaft, some multiple times, always at the starting line.
Old Dec 21, 2014 | 02:36 AM
johnnysixx80
Its all.good.tho just upset they.would throw.another ********.trans in my and keeping the vette trans just wrong but when I pulled out.my old trans Instantly knew wasnt vettw trans besides the cut output shaft and didnt have the v in the trans case but the trans I pulled out was a md8 case from what I red was a good heavy duty case most likely from a truck
To 85 vette trans issues help
