4l60e blues
Old Dec 20, 2014 | 06:52 AM
james27882's Avatar
james27882
2nd Gear
Default 4l60e blues
i just bought a 94 and had it 4 days, i first noticed the car drove fine as long as i took off in drive4 on the way home i decided to turn it loose once to become acclimated to this new found glory. at the stopsign i pulled her back into L1 and ....nothing,moved to L2....nothing,moved it to D3 and it moved somewhat with slipping,shifted into d4 and it did what it was supposed to do.drove it with no problems the next 3 days and it quit in all forward gears but still have reverse.My question is i want to put a new valve body in it but im not sure if what i have in the car is a pwm or not....the ones im am looking at buying on ebay has pwm or non pwm. which one do i need?
Old Dec 20, 2014 | 08:46 AM
RF1's Avatar
RF1
You may want to address the broken forward apply piston in the input drum.
Old Dec 23, 2014 | 07:24 AM
james27882's Avatar
james27882
2nd Gear
just as i thought,mever an easy fix.thanks for the reply and i will be putting her in the shop today.
To 4l60e blues
