Brake problems - serious
Old Jan 2, 2015 | 10:17 PM
RUU's Avatar
RUU
Originally Posted by 66cutlass
Replaced calipers, hoses and pads. It is great. No more pull to either side. However, the brake pedal does not pump up to a solid brake.
Manual bleed or vacuum bleed? Sometimes, with a manual bleed, the brake pedal gets pushed further than usual which can damage the seals in the master cylinder.
touyech2883's Avatar
touyech2883
What do you mean? Does the pedal sink to the floor?
Old Jan 3, 2015 | 12:29 AM
whalepirot's Avatar
whalepirot
Ditto.
Spongy pedal is air or silicone fluid. Then you have ABS which I don't know how to bleed.
Old Jan 3, 2015 | 12:40 AM
66cutlass's Avatar
66cutlass
the brakes are spongy and go all the way to the floor at times. I have to pump up the brakes to get a good hard pedal. I did put on a new master cylinder and completely bled brakes (starting from right rear, left rear, right front left front) until all the new fluid replaced the old fluid. No all the fluid is good and clear.
Old Jan 3, 2015 | 12:41 AM
66cutlass's Avatar
66cutlass
I bled the brakes three times.
Old Jan 3, 2015 | 10:03 AM
touyech2883
Bleeding the brakes on and older gm can really be a pain in the rear. Sometimes especially if you replaced the master. You have the right sequence RR LR LF RF if you have no leaks you just have to keep on bleeding there is air still in there. Sometimes it takes an hour or more with 2 guys to get those old systems to bleed out and the pedal solid again.
If you didn't bench bleed the master before Installing the air could be trapped in the master. Go around and bleed with 2 people with the up down method. Open bleeder press pedal down, close bleeder raise pedal. Do this until you get a more solid pedal. I've even had some luck doing this with the car running, helps move more of the air/fluid out. That's the best way I've found to bleed them, hope this helps.
Old Jan 3, 2015 | 11:21 AM
eutu1984's Avatar
eutu1984
2021 C4 of the Year - Modified Finalist
When I replaced my master cylinder and rebuilt the calibers the only way I was able to get all the air out of the system was to actuate the ABS while bleeding, THe a big burb of air came out the passenger side rear and all was fine.
Old Jan 3, 2015 | 01:02 PM
aklim's Avatar
aklim
How would you do that without some sort of tool like the Tech One, IIRC, to activate the ABS?
Old Jan 3, 2015 | 02:04 PM
eutu1984's Avatar
eutu1984
I did it in a way I do not recommend. I unpluged the ABS computer then ran power directly to the pin that activates the pump, I do not no if this activates any of the valves but when I bled the brakes with the pump running a big gulp of air came out, I then went and bled the rest of the calibers and the brake pedal has been solid since, I plugged the ABS back in took it for a ride and tried locking up the brakes and the ABS worked.
Old Jan 3, 2015 | 02:17 PM
aklim's Avatar
aklim
Might have to take it to GM or someone with the tools.
Old Jan 3, 2015 | 06:07 PM
DinoBob's Avatar
DinoBob
Take it to a parking lot and force the abs to work.
Old Jan 3, 2015 | 06:12 PM
eutu1984's Avatar
eutu1984
That will not work you need to activate the ABS while bleeding the brakes.
Old Jan 3, 2015 | 07:00 PM
  #33
aklim's Avatar
aklim
How? It only works when energized and how would you activate it except for a second or two? Why not get someone with the tools to do it instead of fudging it on your own? This is critical not trivia. Stopping is kinda important. Don't screw with my safety.
Old Jan 3, 2015 | 08:58 PM
  #34
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
This is a first.
Seems like a reasonable problem solver.
Old Jan 3, 2015 | 10:13 PM
  #35
jv9999's Avatar
jv9999
Bleed it again, preferably a pressure bleed.
Old Jan 3, 2015 | 11:57 PM
  #36
aklim's Avatar
aklim
Originally Posted by JrRifleCoach
This is a first.
Only thing I don't know for sure is if the motor is built for continuous use. Before I risk it by running a 12 volt line and hope not to burn something out, I'd check and see with the fsm
