Brake problems - serious
Old Dec 23, 2014 | 09:53 AM
66cutlass's Avatar
66cutlass
Default Brake problems - serious
When I apply the brakes soft or hard - my car pulls to right. Sometimes it almost jerks the wheel out of my hand jerking to thE right.
Any help appreciated.
Old Dec 23, 2014 | 09:54 AM
66cutlass's Avatar
66cutlass
It is a 1986 Z51
Old Dec 23, 2014 | 10:00 AM
l98tpi's Avatar
l98tpi
Max G’s
Could be multiple things. First thing I would check would be the front wheel bearings and tie rod ends. Just hoist the car up and see if you have excess movement in the wheel/tire and then check tie rods.
Old Dec 23, 2014 | 10:03 AM
66cutlass's Avatar
66cutlass
I will look at these items. I know that I need to replace the ball joints.
Old Dec 23, 2014 | 10:27 AM
Churchkey's Avatar
Churchkey
Brake pulling: Normally caused by sticking calipers.
If the brake hoses are original suggest replacement.
Old Dec 23, 2014 | 10:45 AM
c4cruiser's Avatar
c4cruiser
Bleed each caliper. If any one caliper has severely reduced fluid flow or the fluid doesn't flow at all, remove the flex line and see if fluid comes out. That will determine if the caliper needs to be replaced or the flex line.
You didn't say how old the calipers and lines are, but it may be worth replacing them anyway.
Old Dec 23, 2014 | 02:23 PM
aklim's Avatar
aklim
From your post, you seem to be jerking a lot so you are handy. Lift front off the ground and spin the wheels. See if any of them hang up. Have someone gently push the pedal in and see which one grips more. Jerk off the wheel and check the caliper and see if the pins are crudded up. On principle, I would put a wire wheel on the caliper and put brake caliper grease on the.
Also, have you thought of the suggestion of just changing out the calipers AND brake likes? Goodridge makes good SS braided hose. I have them. Then bleed all calipers.
Old Dec 23, 2014 | 06:49 PM
DinoBob's Avatar
DinoBob
My guess is a stuck caliper or a leaking caliper and wet brake pads. A leaking caliper will grab like mad. Scarily so. You could also havea badly glazed rotor if it is a stuck caliper.
Old Dec 23, 2014 | 10:19 PM
jv9999's Avatar
jv9999
The caliper and flex hose others suggest are good candidates. The other is the ABS pump. There are solenoids for each of the front wheels that control fluid flow. They tend to seize up if the fluid isn't changed regularly. If the LF solenoid is seized it will pull hard to the right. Just something else to consider.
Old Dec 24, 2014 | 10:51 AM
whalepirot's Avatar
whalepirot
Severely jerking wheel, suggest a front brake; probably the side opposite the direction of jerk is.
A full and proper bleed would include checking for discoloration in color of the fluid darker indicatiing water adsorption, and possible corrosion in the calipers, causing the restrictive braking.
Sometimes, the 'pull' is resolved with a fluid change.
Old Dec 24, 2014 | 12:30 PM
aklim's Avatar
aklim
I get the fluid out, take the reservoir out, clean it, wipe up any fluid I can see on the master cylinder and refill. After which. I bleed all brake lines till I get clear fluid and 10 more pumps to be sure.
Old Dec 24, 2014 | 03:57 PM
touyech2883's Avatar
touyech2883
My 2 cents is the right front is working normally hence it's pulling that way and working, the left is probably the problem not applying and brake on the left front and letting the right do all the work causing the dive to the right. Try to compress the LF caliper if it's stuck, open the bleeder and try again if it does move with the bleeder open then it's the hose if still dosent move it's the caliper. Hope this helps.
Old Dec 24, 2014 | 04:22 PM
aklim's Avatar
aklim
FYI, regardless of what you find, one bad front means BOTH sides are replaced. I don't care if you never drive again but if you do stopping is NOT optional. Definately if I am on the same road as you
Old Dec 26, 2014 | 03:07 PM
whalepirot's Avatar
whalepirot
If the rubber hoses to the calipers are original, they may need replacing. If restricted flow to a caliper exists, it is not really easy to just inspect, AFAIK. Replacement hoses, IF the caliper check mentioned or fluid flush does not remedy the 'pull', is not pricey.
Old Dec 26, 2014 | 05:06 PM
ghoastrider1's Avatar
ghoastrider1
FIX your brakes. Some teens put it off back in 1980. Hit the brakes hard, swerved over into my lane(2 lane). Head-on, 3 were killed, 2 hurt very badly and I STILL limp from the damage to my knee and hip. Don't live with this happening to you. fix it.
Old Dec 26, 2014 | 08:41 PM
garys vette's Avatar
garys vette
Brakes are NBD. They just work. Very well designed system. If it is not working fix it, hoses first change them!!!!. Easy and necessary.
Then check calipers..
You will get it. You must get it.
Old Dec 27, 2014 | 02:57 AM
Cliff Harris's Avatar
Cliff Harris
Brake hoses are actually two hoses, one inside the other. Sometimes the inner hose leaks and the pressure pinches off the inner hose so the caliper doesn't work. Check your hoses for swollen spots. This one is swollen at the bottom and near the shock mounting bolt:
To Brake problems - serious
Old Dec 27, 2014 | 03:02 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
These cars are old. And the brakes are too often overlooked.
Do it right.
Old Dec 29, 2014 | 12:27 PM
66cutlass's Avatar
66cutlass
You have all been great. I have ordered two reconditioned calipers, pads, and new lines. Hope to get installed by end of week.
Will update.
Old Jan 2, 2015 | 10:09 PM
66cutlass's Avatar
66cutlass
Replaced calipers, hoses and pads. It is great. No more pull to either side. However, the brake pedal does not pump up to a solid brake.
