Cleaning cat
Old Dec 23, 2014 | 11:49 AM
Mike1985's Avatar
Mike1985
Default Cleaning cat
Hey all, I have an 85 vette with an aftermarket exhaust that was put on approximately 10 years previous to me owning it. Should I be worried about all the Dust or any toxic chemicals inside it?
Old Dec 23, 2014 | 11:52 AM
Mark8801's Avatar
Mark8801
I don't think I would lick the inside of it...
Old Dec 23, 2014 | 11:56 AM
Mark8801's Avatar
Mark8801
Is the cat coming apart? I've never heard anything about the dust or material inside being toxic.
Old Dec 23, 2014 | 12:22 PM
Mike1985's Avatar
Mike1985
No it's not coming apart, just want to take it off to clean It out to make a "test pipe"
Old Dec 23, 2014 | 02:20 PM
aklim's Avatar
aklim
Could you buy a test pipe? If not, take it out and blow air into it to get the dust off. And if a long steel rod should slip, make sure it does not hit any of the honeycombed part of the cat again and again or it will break it apart. If it does break apart, compressed air will blow out the dust.
Old Dec 23, 2014 | 02:46 PM
c4cruiser's Avatar
c4cruiser
Unless there's a reason to think that the cat or any interior portion of the exhaust system is coming apart, there's no real reason to bother with it. Do you hear any sort of rattling from the exhaust when the engine is running?
Are there any indications of rust that have created pinholes or spots so weak that you can push on the pipe and move it? Condensation will form inside the exhaust and if the engine doesn't always run long enough, rust/corrosion can develop.
If you want to make a "test pipe", that's between you, your exhaust shop, and whatever emissions testing you have to have done.
Old Dec 23, 2014 | 02:50 PM
aklim's Avatar
aklim
I know there is probably little difference for a stock application but if you intend to race, any little bit helps. That said, if you have a free flowing cat, it probably won't hurt your performance enough to notice but how much difference between the stock cat and the free flowing cat? IDK.
Old Dec 23, 2014 | 04:21 PM
Mike1985's Avatar
Mike1985
I want to clear out the cat. That would involve knocking out all of the honeycomb inside of it
Old Dec 23, 2014 | 04:22 PM
Mike1985's Avatar
Mike1985
I do hear a lot of rattling when under heavy acceleration
Old Dec 23, 2014 | 10:29 PM
WW7's Avatar
WW7
If you hear rattling then the cat is shot..The media inside has broken apart and will eventually clog the pipe, or at least restrict flow.....If you want or need to retain a cat, then get a Magnaflow cat, the one I got as a replacement is so free flowing you can hold it up to the sky ,look through it , and see birds flying by...The only thing in it is a couple screens, so there is almost zero restriction......WW
Old Dec 24, 2014 | 01:13 AM
crowz's Avatar
crowz
Also if your doing this for some "performance" improvement and theres nothing really wrong with the cat... don't.
I gutted mine on my 86 and all it did was make it louder. Zero change in 0-60, 1/4 mile, top end, etc.
Old Dec 24, 2014 | 05:09 AM
DinoBob's Avatar
DinoBob
And stinky exhaust that irritates others, needlessly pollutes, and will attract the attention of some car-savvy policeman. I'd pull over every guy who routed out the cat.
Old Dec 24, 2014 | 06:46 AM
crowz's Avatar
crowz
Actually the "stinky" exhaust is with the cat
Smell goes away normally removing them.
On the first gen of cats it was a good idea to gut them as they were very restrictive but by the time the c4 came out the flow is actually very good with them. Agreed its better to keep the cats on.
Old Dec 24, 2014 | 09:30 AM
cv67's Avatar
cv67
St. Jude Donor '05
You can knock the insides out just dont breathe the stuff
Old Dec 24, 2014 | 09:35 AM
aklim's Avatar
aklim
Originally Posted by crowz
Actually the "stinky" exhaust is with the cat Smell goes away normally removing them.
That is weird. When it was running rich, I had more of a rotten egg smell.
For me, I took them off and put them back on for noise control. Just gave it more noise and if the gain is insignificant, why should I put up with more noise?
Old Dec 24, 2014 | 09:39 AM
whalepirot's Avatar
whalepirot
Originally Posted by WW7
get a Magnaflow cat... almost zero restriction.
timely, as I am looking into adding a pair.
Agreed; also my experience.
And stinky exhaust will attract the attention of some car-savvy policeman.
As a federal offense, not mentioned in THIS thread, but many others, it is a very expensive fine, a blemish on the hobby, for little or no gain.
Actually the "stinky" exhaust is with the cat. Smell goes away normally removing them.
Agreed its better to keep the cats on..
Perhaps, but not if if the system is functioning properly. Any smell is probably due to lack of AIR injection or a used up catalyst.
Old Dec 24, 2014 | 09:44 AM
aklim's Avatar
aklim
I have Random Technologies cat and removed the AIR. Easier to work around the engine and the cat brings down the noise a lot. I'll put up with the noise IF it can generate enough power but not if it doesn't.
To Cleaning cat
Old Dec 24, 2014 | 10:23 AM
John A. Marker's Avatar
John A. Marker
The rattling you hear at hard acceleration in your 85 is just due to the age of the car ...not the cat. if anything I would build a "test pipe". An exhaust shop will not remove the cat for you and let your drive off. There is too big of a fine for their business to take the chance. See if you can find a place that buys old cats. Find the cat for an 85 and cut off the flanges, then weld in pipe. The 85 cat bolts in and out. When I had my 85, I would take it to the track and replace the cat with my test pipe. The pipe plus March underdrive pulleys was worth 1/2 second at the track.
Old Dec 24, 2014 | 10:29 AM
whalepirot's Avatar
whalepirot
enough power
LOL I have never had enough power!
I mentioned the federal EPA fine not in judgement, but to inform others of an expo$ure some may unaware of. I've run w/o one while fixing an extreme rich mixture, which will ruin a cat.
I saw virtually no improvement in performance WITH the stock CAT.
Old Dec 24, 2014 | 11:24 AM
Mike1985's Avatar
Mike1985
I was hoping to get some performance gains from this. I had read somewhere that itll add some SOTP feel to the car. Also I assume it's all clogged up because they car's exhaust wreaks...
