'92 LT1 Rough Idle issue
The opti can cause this effect as well. It may also cause the tach to bounce around at idle.
When in high gear and accelerating, does it buck or kick after warm up. This is a opti symptom.
Where is the ICM located [ that's ignition control module, right ?] and how expensive and hard to change is it ??
What is the IAC motor and what does it do ? How do you test it ?
OPTI is the distributor assembly ??? How is that tested ?
Sorry for the basic questions but I am new to this car,, had a '95 Z28 LT1 and never had any issues.
These modern electronic nightmares always worry me .... My '71 Chevelle 454 never gives me any grief .... I have had that ride for 15 years with minor issues that I have easily fixed..... easy to work on !!!!
Thanks,,,,
Finally, when these conditions are present it will sometimes stall when taking off from a stop, not always ...... but starts back up. When these low rpm problems are present, if you get on the highway and cruise at 60 to 70 mph,, runs fine ......
Any ideas ? Could a problem with the EGR system cause something like this...
If it does it when it's warm, I would like to get a reading on fuel pressure at the time of the occurrence.
There are a few things you can still check and see if all is good. But I would not take the opti off the list yet.
