L98 to LT1
Old Dec 27, 2014 | 12:18 PM
mcdonaldheat's Avatar
mcdonaldheat
Default L98 to LT1
Hey Everyone, looking for a little advice. I am pulling off my tpi and heads and replacing them with LT1 heads (ported) and intake. I have the mod done for the reverse cooling issue. The engine will be a stock bore roller block. I am looking at the melling cam and here are the numbers. 220 intake 231 exhaust at.050, SAE specs at .06 are 304 intake 287 exhaust. Cam lift .312/.320. Gross valve lift .468/.480. Centerline 106/114.
I am probably gonna run around a 2400 stall with about a 3.73 gear. Long tube Hedman Headers with a free flowing exhaust.
Does it seem that this cam will work well with this setup?
Many Thanks
Old Dec 27, 2014 | 03:08 PM
mcdonaldheat
Many Thanks
Never Mind. I just now went ahead and ordered the lt4 hotcam. I was trying to save money and decided the engine wasn't the place to save.
Old Dec 27, 2014 | 05:01 PM
DanielRicany's Avatar
DanielRicany
People have had great luck with the LT1 hotcam. I'm interested to see how this all works out.
Old Dec 28, 2014 | 11:53 AM
mcdonaldheat
I will try to post some pictures and keep this thread going as I complete this work with the engine. It is raining here today. I hope to have it in the car and on dyno by early spring depending on dollars.
What I am trying to copy is an article on Super Chevy where they built a sbc roller engine for a thousand bucks and got around 400hp at the crank. I am already at that cost and I haven't even started to put my engine back together.
Wish me luck.
To L98 to LT1
