Performance mods
Old Dec 30, 2014 | 03:53 PM
karkrazy1971's Avatar
karkrazy1971
Default Performance mods
I'd like to hear from other C4 owners on what mods you've done to your car? I have a 1996 LT4 that I'd like to squeeze another 100HP out of.
Old Dec 30, 2014 | 04:16 PM
gears's Avatar
gears
Heres what I did..
https://www.corvetteforum.com/forums...ine-build.html
Old Dec 30, 2014 | 04:46 PM
karkrazy1971
Originally Posted by gears
That is a sweet setup. I'd like to do that on mine further down the road. Got to start with the basics.
Old Jan 5, 2015 | 02:41 PM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
Did you ever dyno the car?
Old Jan 5, 2015 | 07:20 PM
96 lt-4's Avatar
96 lt-4
What is your budget?
The first thing I did to mine was long tube headers.Followed by 4.10 gears.Then I did a cam and the motor went south in a hurry(not the cams fault the thrust bearing on the crank was shot and I didn't realize it at the time).Then it became 383 with cam/afr heads/EWP/msd ignition/dyno tune.
If I had it to do over I would go with long tube headers/maybe a hotcam/and a tune.May not be 100hp but look up JONECAP and what his was running with not much more.
It all comes back to what your budget is.
Old Jan 6, 2015 | 10:36 AM
karkrazy1971
Thanks for the reply. I planned on doing the exhaust first, but wasn't sure about swapping out the cam. I'll like do a similar setup to what you have. Want to spend a total no more than $3k
Old Jan 9, 2015 | 03:52 PM
ch@0s's Avatar
ch@0s
I went LSx after modding My L98 till it gave up the ghost.
https://www.corvetteforum.com/forums...x-my-swap.html
To Performance mods
