Performance
Old Dec 30, 2014 | 05:48 PM
breezee13's Avatar
breezee13
1st Gear
Default Performance
Hi everyone new to the thread & forum world. I have a 1986 Corvette 105,xxx miles... only thing done to it is a bigger throttle body, k&n air filter, and flowmaster exhaust. looking to replace my valve guides soon and figured might as well do a complete overhall while i have it apart and was wondering what some easy performance modifications would be thanks!!
Old Dec 30, 2014 | 06:59 PM
THE 383 admiral's Avatar
THE 383 admiral
basics first. The TB on a stock TPI, unless it was free. Money was wasted.
gears, LT1 cats or elimination, headers, quality 1.6 roller rockers apprx .30+ lift, a slight gain. Lower stat, TB iac coolant bypass. Prom Tune!
depends on your goal. And your wallet limit.
Old Dec 30, 2014 | 09:11 PM
aklim's Avatar
aklim
No such thing. Performance is neither cheap nor easy. If the heads are coming off, I would ask why. Are you sure the short block is good? If so, change the cam.
When I rebuilt, I changed the cam to match the AFR heads, intake and headers. Also the Roller Rockers were 1.5 and 1.6 to match the cam profile. Dyno tuning.
While you are there, dump the injectors if they are stock Multecs. Change the fuel pressure regulator and the hoses. Your K&N and the TB don't make power really unless the rest of the pieces are supporting it.
Old Dec 30, 2014 | 09:12 PM
aklim's Avatar
aklim
Actually, my buddy did JUST the TB and the coolant bypass. Made several runs with it, took it off and put the stock one back. Guess what. Stock was faster consistently.
Old Dec 30, 2014 | 09:17 PM
ghoastrider1's Avatar
ghoastrider1
195 AFR heads and headers for a start.
Old Dec 30, 2014 | 09:24 PM
aklim's Avatar
aklim
Intake and prom too.
Old Dec 30, 2014 | 09:55 PM
touyech2883's Avatar
touyech2883
why are you replacing the valve guides?
Old Dec 30, 2014 | 11:01 PM
THE 383 admiral
1st as I stated on a stock engine, The TB is a Waste of money.
Technically if you install a bigger TB and do not re-tune, your AFR is now against your true potential. It's a proven fact the ported / larger TB will deliver more CFM this will pay off especially with heads, Cam, inj, intake.
Old Dec 30, 2014 | 11:09 PM
aklim's Avatar
aklim
It was for him as I said he did go slower with it when stock.
To Performance
