87 steering wheel column help
Old Jan 3, 2015 | 10:19 PM
mitchpdavis's Avatar
mitchpdavis
Default 87 steering wheel column help
Any body know where I can find a exploded diagram of the 87 steering column.. I broke a little plastic part and have no idea what it was . Also I can't get my key to turn to the lock position. . It just stays on the whole time..
Old Jan 3, 2015 | 10:24 PM
joeld's Avatar
joeld
[QUOTE=mitchpdavis;1588635252]Any body know where I can find a exploded diagram of the 87 steering column.. I broke a little plastic part and have no idea what it was . Also I can't get my key to turn to the lock position. . It just stays on the whole time..[/QUOTE
This might help.
Joel
http://www.elcaminocentral.com/artic...n/Scan0001.jpg
Old Jan 3, 2015 | 10:28 PM
mitchpdavis
Well maybe a lil.. I think my locking pin is on of the issues with my key not going to the lick position. . But I nee to know that the plastic part is that is on top of the lock plate.
Old Jan 3, 2015 | 10:36 PM
joeld's Avatar
joeld
Try this one.
http://ls1tech.com/forums/general-ma...oval-pics.html
Old Jan 4, 2015 | 12:33 AM
mitchpdavis
Ugh... no not at all... The vette has a very different setup... I guess there is a lot of the same **** but before the lock plate there is a plastic "shield" I guess you would call it.. I'm pretty sure it dose something for the horn because without it my horn stays on as soon as the battery is connected.
Old Jan 4, 2015 | 09:27 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
From my 86 Service manual
http://dankai.shawwebspace.ca/asset/...ing_column.pdf
Old Jan 4, 2015 | 11:23 AM
WVZR-1's Avatar
WVZR-1
This is a pretty good image of the "horn contact retainer":
http://www.ecklerscorvette.com/corve...1970-1989.html
For an early car there's this retainer, the cancelling cam and a very short tower that's inserted into the steering wheel that control horn function. You mentioned "small" and this is the most frequently demolished part broken on nearly every entry into the steering column under the steering wheel.
All of the resellers carry this part. If you search GM# 7808365 that's the retainer you should find, the tower GM # 9768768 and the Cancelling cam GM# 7849228 but both tower and cancelling cam aren't available from some of or all of the resellers.
Old Jan 4, 2015 | 11:33 AM
mitchpdavis
Yea that's it.. pain in the *** to find locally. . In fact I can't find it at all.. gotta order it.
To 87 steering wheel column help
