1993 C4 No Heat
These are the things I've checked...
> Hoses are hot to heater core.
> Fan and heater control module are working.
> AC works fine but when we raise the temp no heat comes out.
> All vents do open when buttons are pressed for that particular one.
> I highly think it is a heat core just because I'm the original owner and this Vette only has 60,000 miles on it. Coolant has ben flushed many times since I've owned it.
I did read about someone saying something about a "Heater Valve" not working. But can't seem to find where that is in the GM manual I have. Is there another name that may full under?
Any suggestions would be appreciated.
There is no heater valve but only a flow restrictor. The water always flows thru the core.
I like to start the engine from cold. Before the stat opens the heater hoses should begin to get hot. They should get pretty hot before the stat opens and be the same temperature. As the stat opens and the radiator hoses get hot, the heater hoses should be as hot as your bottom hose. If all are the same temperature, then there is probably no flow restriction.
You can also remove the blower module form the top side of the evaporator and look inside to see the blend door. Set the door to 60 and then 90 and see if the door changes positions.
A quick check is provided to you by atgordon yesterday (1/5/15) and other info from Cliff Harris showing this blending damper door. from under the hood, just remove the small plate with a wiring harness at the top of the heater box (he posted a photo) and see if this damper door will move when you change the settings from extreme A/C to full 90 degree heat. If yours is like mine, it will not move and allow air to flow through the heater core and give you heat.
If the damper door is stuck, then look at and probably replace the #51595 elec motor which is inside the car right above your passenger's feet. Look at other posts and mine (john6277) to see how you remove the fuse panel covers to access the knee pad under the dash - be careful as this piece has plastic tabs in the front that are probably quite brittle.
This is really a pretty simple check and fix in less than an careful hour of time. Have fun John
Turns out the blending door was working fine, then went to flushing the heater core that took care of the problem.
Couldn't believe this was the issue since we flush this system every 4 to 5 years and the corvette only has 60,000 miles on it.
Guess you learn something new all the time.
Thanks for everyones help.
I don't think my car had good care before I got it which may contribute to this condition.
