Oil Leak - engine pic needed
Old Jan 18, 2015 | 07:31 PM
puzzigully's Avatar
puzzigully
Default Oil Leak - engine pic needed
Hi does anyone have a clear pic of the rear drivers side of the Engine for a 1987 Corvette?
I have an oil leak, but being a B2K there almost no room to see where it's coming from.
I can just see the oil temp sender from below, but want to see where it is in relation to the oil pressure sender and oil filter hosing, so i can try to track this down.
Ultimately, I'd love to see an engine out of the car, then it'd be clear, where each of these components are
Old Jan 19, 2015 | 12:56 AM
Cliff Harris's Avatar
Cliff Harris
The oil pressure sender is located on the back of the block:
Some time after 1986 the oil pressure switch and oil pressure sender were combined into a single unit with a 3 wire connector.
Old Jan 19, 2015 | 07:17 AM
puzzigully's Avatar
puzzigully
Can you zoom out a bit so I can see more of the motor
Old Jan 24, 2015 | 02:17 AM
drive it's Avatar
drive it
That pic is with the intake manifold and heads off. It's looking at the firewall from the lifter valley.
Hope that gives enough perspective .
Old Jan 24, 2015 | 09:22 AM
WVZR-1's Avatar
WVZR-1
There's very good images in the FSM - This LH rear from an '86 that shows the OPS, OPT etc
Name:  LH rear engine.jpg
If you have a FSM the various images are at 8A-201 or the vicinity.
Images aren't going to find "YOUR" oil leak. There are a multitude of various possible sources. A well placed mirror or maybe even a "bore-scope" might help you OR if it's a high miler just reseal the intake, do VC gaskets and inspect the switches/senders and fittings when you disassemble it.
To Oil Leak - engine pic needed
