1986 Tune up questions
Old Jan 20, 2015 | 05:12 PM
jasonkraft's Avatar
jasonkraft
Default 1986 Tune up questions
I'm getting ready to do a tune up and wanted to know your opinion on plugs and wire recommendations
Old Jan 20, 2015 | 07:55 PM
Dt86's Avatar
Dt86
It will depend on if you have iron or aluminum heads. They use different plugs. I use ac delco parts.
Old Jan 20, 2015 | 09:09 PM
aklim's Avatar
aklim
I don't mind spending on plug wires but I wouldn't buy some high tech stuff for plugs. I usually toss them out within 2 years. As to plug wires, how handy are you? I have a set of MSD wires that have no ends. I had to crimp it. I bought the crimper and cut them to length. AS to plugs, I just use some decent NGK plugs.
Old Jan 20, 2015 | 10:15 PM
jasonkraft's Avatar
jasonkraft
It has aluminum heads, I have a new set of msd street fire 8mm bought for my chevy truck that is long gone. Just have to figure out how to crimp the ends on, getting ready to check you tube. I've used Taylor wires in the past and was really happy with them (had a 92 stang and went through 2 sets of accel in 1 year then switched to Taylors). Which NGK plugs are you using?
Old Jan 20, 2015 | 10:26 PM
aklim's Avatar
aklim
If it is stock, go look up the chart. I have AFR heads so it doesn't matter what I use.
http://www.summitracing.com/search/p...imping%20Tools
Old Jan 20, 2015 | 10:40 PM
jasonkraft's Avatar
jasonkraft
Thanks I'll check that out. It's stock, not sure about the internals. It's got 180k miles on it and runs strong.
Old Jan 20, 2015 | 10:43 PM
jasonkraft's Avatar
jasonkraft
I just checked the garage and found the Taylor crimper and the MSD mini crimper that came with the wires
Old Jan 20, 2015 | 10:58 PM
aklim's Avatar
aklim
ASSUMING the boots are good, all you need is a razor blade and a bunch of good terminals. IF that is the route you want to go, I would put you wire looms in place first then get the wires going so you can cut to length. Being they are not new, I would test them first. Find a car they can fit on, run it in a garage and spray a fine water mist AROUND the plug wires. Any light, toss.
Old Jan 20, 2015 | 11:27 PM
jasonkraft's Avatar
jasonkraft
The wires are new, opened the box and put on the shelf because I sold the truck. The ends have never been crimped on so they should be good. Just wish I had sprung for the better crimper.
Old Jan 20, 2015 | 11:51 PM
aklim's Avatar
aklim
If you want to know the internals, drive for 3000 miles, send oil sample for analysis to see if anything is worn out. Before I go there, I would run a compression and leakdown test. At 180K, I don't hold any high hopes for that motor.
Old Jan 20, 2015 | 11:52 PM
aklim's Avatar
aklim
Unless you want to swing by Milwaukee, that is what you got, that is what you work with. I have the MSD one and it is nice.
Old Jan 27, 2015 | 05:02 PM
86C4Z51's Avatar
86C4Z51
http://www.magnecor.com/magnecor1/main.htm
Best wires you can get, custom made (no measuring/crimping) and lifetime guarantee. Cost you about $130 for the set.
Old Jan 27, 2015 | 07:00 PM
aklim's Avatar
aklim
Do you own a set? I'd be curious as to how they fit. I have them coming over the valve cover and down to the plugs via wire looms.
Old Jan 27, 2015 | 07:02 PM
jasonkraft's Avatar
jasonkraft
Thanks guys, I got the MSD wires made up and installed. The tool they came with worked great ordered a Taylor cap and rotor and used the AC plugs. Everything went good and boy did it pep the car up but no. 2 was a pain, I think they built everything around that plug
Old Jan 27, 2015 | 07:05 PM
jasonkraft's Avatar
jasonkraft
Next is a smog pump delete since mine is making a little noise. What do you have to do to plug the lines on stock manifolds?
Old Jan 27, 2015 | 07:09 PM
c4cruiser's Avatar
c4cruiser
The threaded end of the tubes on the manifold is a 1/2" NPT thread. Just go to Lowe's or Home Depot and get a couple of 1/2" caps. USe some anti-seize on the threads.
Old Jan 27, 2015 | 07:26 PM
jasonkraft's Avatar
jasonkraft
Thanks, my weekend projects are piling up. I have to go measure for the bracket and fab something up
To 1986 Tune up questions
Old Jan 27, 2015 | 07:32 PM
aklim's Avatar
aklim
You can't find a commercially available unit?
Old Jan 27, 2015 | 07:49 PM
jasonkraft's Avatar
jasonkraft
Yeah but I have a machine shop in my basement and it's too cold to do anything else on the weekends, it should only be a cost of the pulley
Old Jan 28, 2015 | 07:27 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Here is some measurements from a delete I built years ago.
http://members.shaw.ca/dankai/Air%20...Delete%20Info/
