Drive shaft bearing assembly question..Help!
Old Feb 1, 2015 | 06:29 PM
kleptopigdog's Avatar
kleptopigdog
Default Drive shaft bearing assembly question..Help!
Can some one give some information on the bearing at the front of the drive shaft .When my driveshaft was out Matt told there was a lot of play in. They couldn't find one ,today i tried to locate the bearing but no one knows any thing about it .Even the FSM is vague on it . Thanks
Old Feb 1, 2015 | 06:51 PM
aDigitalPhantom's Avatar
aDigitalPhantom
Are you talking about the ujoint?
Old Feb 1, 2015 | 06:56 PM
kleptopigdog
Not the u- joint but a bearing in there.
Old Feb 1, 2015 | 07:20 PM
RobnLisa's Avatar
RobnLisa
The u-joint has needle bearings in it. No other bearings in a drive shaft that I have ever seen. Replace the u-joints and everything will be fine.
Old Feb 1, 2015 | 07:31 PM
kleptopigdog
Old Feb 1, 2015 | 07:35 PM
RobnLisa's Avatar
RobnLisa
Yep thats the u-joint
Old Feb 1, 2015 | 09:04 PM
csthews's Avatar
csthews
Definitely a U-joint. That picture is a bit confusing, but what is referred to as the bearing and bearing cup is really the u joint. Anyway it is too bad it wasn't replaced when the drive shaft was out. Taking out the drive shaft can be a royal PITA and u-joints can be bought at any parts house.
Old Feb 5, 2015 | 09:14 AM
hcbph's Avatar
hcbph
Good source is RockAuto also.
Old Feb 5, 2015 | 10:25 AM
WVZR-1's Avatar
WVZR-1
I doubt that it's the u-joint that they were referencing but maybe the transmission extension bushing. You don't mention which transmission so it's very likely that they coulld have had issues in an attempt to locate the correct bushing.
Which transmission do you have? A4, M6 or an older 4 + 3?
Old Feb 5, 2015 | 11:09 PM
gerardvg's Avatar
gerardvg
Are you thinking of the rear transmission bush?
I know there is a bit of play between the yoke and the bush in the transmission extension housing, that is normal it did concern me at first many years ago but was told it was normal.
Has not given me any trouble.
I know my tail shaft / drive shaft yoke has a ring around it that looks like a ballancer, that is on tight and doesn't move. It could be mistaken as a bearing.
Old Feb 6, 2015 | 05:23 AM
WVZR-1's Avatar
WVZR-1
OP never mentioned if the car is an A4 or what BUT yes I believe that the dampener on the front slip yoke could maybe mistakenly or "jokingly" referred to as a drive-shaft bearing. OP hasn't been back either.
Old Feb 6, 2015 | 07:46 PM
kleptopigdog
Sorry been busy.Yup that's what it is. Car is a 94 with an automatic. I guess it's used to balance the shaft. It's wore out and moving around about half an inch.
To Drive shaft bearing assembly question..Help!
