1) Code 32 - EGR, probably the EGR sensor again, and this will be my 3rd. Been there, done that.
2) Code 36 - something to do with the MAF relays. Never had this one before. I should check connections first, but if it's still there, then what? Replace the burn off relay? What else?
I have an '85, and my code 36 is an ignition system circuit error or transaxle shift problem if equipped with the 4T60E transaxle. I think codes 33 and 34 deal with MAF misreadings/malfunctions. If you have an '86-'89 your burnoff and power relays are located on the firewall behind the battery. You may want to change both. :seeya
