383 LT1 with FIRST intake
Old Feb 3, 2015 | 05:24 PM
c487's Avatar
c487
Default 383 LT1 with FIRST intake
A couple years ago I was going to do a 383 with a FIRST intake for my 87 but it never happened. I just picked up a 92 coupe for $3600 and will be building a 383 with the FIRST intake for my daily driver. I am just looking for a fun reliable street car that makes lots of power under 5000. My dad and I just pulled the engine so it will go out for machine work this month. I hope to have the car on the road by the end of May. When all the bugs are worked out I will get it on a dyno to see what the numbers look like. Here is what the build looks like so far
Scat forged crank 3.75 stroke
Scat pro comp 6" I beam rods with 7/16 bolts
Mahle Forged flat top pistons with coated skirts 4032 alloy (11:1)
LPE 219 Cam
AFR 195 Eliminator heads street port
FIRST intake manifold
Old Feb 3, 2015 | 08:03 PM
bjankuski's Avatar
bjankuski
LPE 219 Cam
They make a first intake for an lt1?
Old Feb 3, 2015 | 09:11 PM
93VettePilot's Avatar
93VettePilot
Cool. Should be a nice combo.
Old Feb 4, 2015 | 08:23 AM
c487's Avatar
c487
I don't think FIRST makes a manifold specifically for a LT1 but the base can be drilled to work for for it. Its hard to see but if you go to https://www.firstfuelinjection.com the blue 73 chevelle under customers rides is a LT1. I called Ken at FIRST to see if the manifold was ever used on a LT1 and he pointed it out to me. He also offered to drill the holes in the base if I couldn't do it.
Old Feb 4, 2015 | 11:24 AM
THE 383 admiral's Avatar
THE 383 admiral
Interesting, slightly backwards. The LT1 intake is way beyond TPI or FIRST. The 383 alone will provide a huge torque difference.
Old Feb 4, 2015 | 11:25 PM
ezobens's Avatar
ezobens
For under 5000 RPM torque, the FIRST will outshine the stock LT1 and TPI intakes.
My question is the 11:1 pistons in a 'daily driver'?
Seems a bit on the high side to me?
Old Feb 5, 2015 | 10:22 AM
THE 383 admiral
Why is this??? I have 11.3 as my Summer daily driver along with a 110 center line.
did you look at the Cam and Heads listed? cam nothing to radical.
again TPI \ FIRST on a 383 is to much bottom end.
Old Feb 5, 2015 | 10:58 PM
ezobens's Avatar
ezobens
Usually, you want a bigger cam / more overlap with 11:1 static to bleed off some of the pressure to prevent detonation on pump gas. Any idea what the DCR would be on this set-up?
And there is no such thing as too much bottom end.
Old Feb 6, 2015 | 09:04 AM
THE 383 admiral
good luck hooking up, with no such thing as to much.
if a auto that 4l60 \ D36 is going to love it.
Old Feb 6, 2015 | 10:16 AM
c487's Avatar
c487
It it a auto with a dana 36 and 2:59:1 gears. I figured I would get the build done and see what it drives like before selecting gears for the dana 44 conversion. I don't want to gear it real high because I plan to do a good amount of freeway driving. My gut feeling is that I will end up doing 3:07:1
Old Feb 6, 2015 | 10:28 AM
c487's Avatar
c487
I was thinking the cr might be a bit to high as well, but lots of L98 engines go 10:5:1 with the 219 and don't seem to have a problem. I was more worried about cranking pressure (about 211) than detonation. The lt1 with reverse flow cooling seem to handle compression well from what I have seen. I will also hold a tight quench that should help fight off detonation. The static compression will actually be a bit lower than I posted closer to 10:75:1 and I know that chamber sizes usually are a bit bigger than they are advertised to be. I will check them when they get delivered and post the actual size.
To 383 LT1 with FIRST intake
