1988 door hatch release switch
Old Feb 10, 2015 | 08:43 PM
HAD2HAV2's Avatar
HAD2HAV2
Default 1988 door hatch release switch
The passenger door hatch release switch has stopped working. Can they be repaired?
Old Feb 11, 2015 | 01:45 AM
Cliff Harris's Avatar
Cliff Harris
You might have a problem with the wiring associated with the switch (in the door). Assuming the driver's side works, that means that the problem is localized to the passenger side door.
I found several switches with a Google search on "c4 corvette door hatch release switch", so the switches are available.
Old Feb 11, 2015 | 08:35 AM
HAD2HAV2's Avatar
HAD2HAV2
Thanks Cliff. I'll check power to the switch when I remove the door panel to replace the carpet. Just getting ahead of myself.
To 1988 door hatch release switch
