1984 antenna ground
Old Feb 11, 2015 | 08:01 AM
IZ-Boss's Avatar
IZ-Boss
Default 1984 antenna ground
Hello, My antenna has not worked since I bought the car so I bought an after market antenna. My husband put it in it works fine but now my interior lights wont go off. Does anyone know how to fix this.
thank you for any help Robin
Old Feb 11, 2015 | 09:11 AM
s carter's Avatar
s carter
Before things getting overly Technical off the top of my head I dont Know if they are connected by other than by a possible common ground & fuse. I would start is the interior light switch off on the headlight switch? if yes with key on test each door & hatch switch. if you feel that there is a ground problem you can install a second ground on anttenna since thats were all the work was done.
I am tending to lean toward the hatch switch has over adjusted, put some firm pressure over rear hatch latch for a minute and see if the lights go out.
Old Feb 11, 2015 | 10:02 AM
IZ-Boss's Avatar
IZ-Boss
we did that it all started with putting in the after market antenna it wasnt doing this before thanks
Old Feb 11, 2015 | 10:05 AM
IZ-Boss's Avatar
IZ-Boss
after checking that he disconnected the antenna completely and they still wont go off,. thanks Robin
Old Feb 12, 2015 | 01:22 AM
Cliff Harris's Avatar
Cliff Harris
Are you sure you don't have the headlight switch in the "interior lights" position?
To 1984 antenna ground
