What replacement engine can I use?
Old Feb 23, 2015 | 09:31 PM
Teqsand's Avatar
Teqsand
Default What replacement engine can I use?
Hi all,
I picked up an 85 4+3 (had to part with the Z06 to pay bills) and it seems to have what I believe a spun rod bearing....
rather than rebuild, I just want to find a drop in motor that I can use... I'm in calif so I have the smog crap to deal with.... I believe all the TPI stuff is still good, the motor runs but makes a knock (sounds like a bolt bouncing around the lifter valley....
so.... what year(s) 350's can I use to just bolt in and have my accessories bolt on? which cars have that motor? I don;t have much funding so I have to stay super cheap.... I thought about a crate 350 from Jegs but even that 1500 is hard to come by...
any help or suggestions in the way of a replacement is helpful
Who makes a good quality rebuild kit at a reasonable price/?
thanks
Old Feb 23, 2015 | 10:07 PM
jakenks's Avatar
jakenks
If you're in Cali, you can pick up a running engine at a pull a part for dirt cheap, sometimes $2-300. Depends on if you the stuff to pull one and transport it.
Scoggins-dickey has good prices on Mr Goodwrench crate motors.
Old Feb 23, 2015 | 10:19 PM
Churchkey's Avatar
Churchkey
If your handy: Exchange reground crank with bearings 200.00, new con rod, timing gear set, oil pump, rings, gasket set, farm out the heads for a valve job. If flat tappet cam a stock unit with new lifters is cheap. maybe 800.00 total = basically a fresh engine for a driver.
Good luck.
Old Feb 23, 2015 | 10:41 PM
Teqsand's Avatar
Teqsand
I know it's an L98, so is it a Gen 1 block? same as say a 1970 350? all holes the same for accessories?
I have not seen any crate motors labled L98
Old Feb 23, 2015 | 11:08 PM
THE 383 admiral's Avatar
THE 383 admiral
providing it is the original block. It would be a 2piece RMS
Gen 1 block.
Old Feb 23, 2015 | 11:40 PM
Teqsand's Avatar
Teqsand
Gen 1 block.
I thought I read somewhere that in 85 they started the 1 piece rear seal
Old Feb 24, 2015 | 12:22 AM
MavsAK's Avatar
MavsAK
86 actually.
Old Feb 24, 2015 | 01:34 AM
Hot Rod Roy's Avatar
Hot Rod Roy
Check out Larry's Performance Shop in Montebello, Ph: 323-722-8865. They built my engine exactly to my specifications several years ago, and I'm very happy with it. Their price was very reasonable.
Old Feb 24, 2015 | 08:03 AM
ex-x-fire's Avatar
ex-x-fire
I'd do a vortec swap to get a roller cam, better heads, ect.
Old Feb 24, 2015 | 09:26 AM
JackDidley's Avatar
JackDidley
Just needs to be an old school small block. Then get the flywheel to match the crank. Around here the old 350s are getting cheap.
Old Feb 24, 2015 | 02:00 PM
mtwoolford's Avatar
mtwoolford
Also oil pan and matching gasket; can you find a 7 inch pan for a two piece rear seal engine? sure 84 and 85 vettes had them, if you can find one in a junkyard at junkyard prices; if not, then nos or aftermarket either of which is going to be pricey
Old Feb 24, 2015 | 07:38 PM
Teqsand's Avatar
Teqsand
Ok so basically any pre 85 small block will bolt up..... my oil pan won't and flywheel won't work on them???
I'm willing to use my top end if it will plug and play a later block also,,,,
Old Feb 24, 2015 | 07:55 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Any '85 and older 350, your oil pan and flywheel will bolt on and work fine. I don't know why it was suggested that you need to find an oil pan. (?)
Old Feb 24, 2015 | 09:17 PM
Teqsand's Avatar
Teqsand
Any idea what is the latest 350 5.7 I can use? I see a lot of mid 90's stuff, what would I need off my current motor (intake I suppose) heads?
Old Feb 24, 2015 | 11:59 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
You can use up to the last 350 made, if you're willing to change flywheels (any 1 pc RMS), and modify your intake bolt pattern or swap intakes.
Old Feb 25, 2015 | 01:00 AM
mtwoolford's Avatar
mtwoolford
mea culpa; I must have misread something; I thought the original poster had a later one piece rear seal engine and someone suggested using an earlier "old school" small block with a two piece rear seal...which will work just fine, but would require the earlier flywheel and the earlier pan; going from a two piece rear seal engine to a one piece rear seal engine requires a modification to the rear of the pan....Going the other way, I've installed a pan from an earlier two piece rear seal engine onto a later engine with a one piece rear seal...and yes, I had to modify the pan to accommodate the changes in rear seal design
obviously, if he has an 85 with a two piece rear seal engine (maybe the L98 confused me) then any 85 or earlier two piece rear seal engine will work with the existing flywheel and pan. sorry for the confusion
Old Feb 25, 2015 | 07:07 AM
project C4's Avatar
project C4
just a plain goodwrench motor is bolt in for '85 aside from swapping some parts from one motor to the other. pan, balancer ect,
http://www.summitracing.com/parts/na...FZcdgQod_XoAZA
the heads are even the same 624 casting that come on an '85 only difference is the compression is a little lower because the new crate has dish pistons.
To What replacement engine can I use?
Old Feb 25, 2015 | 01:39 PM
Hot Rod Roy
any suggestions in the way of a replacement is helpful
Have you checked CraigsList.com?
Old Feb 25, 2015 | 02:16 PM
tbirdsps's Avatar
tbirdsps
Make sure it's not just a wayward rocker arm/pushrod making the noise.
Old Feb 25, 2015 | 03:01 PM
vader86's Avatar
vader86
Easiest drop-in would be a ZZ4 crate engine, but some things wouldn't swap over directly 1:1. I would go that route myself if I didn't want serious modifications done to it.
There are various crate other engines from GMPP that you can find in Summit or Jegs or even directly, and their specifics are close enough that a chip tune wouldn't be an absolute necessity (though no matter what you do, you do need to have it done eventually).
You can use a 1 piece seal roller cam engine, so you can use any Gen 1 SBC from the 50s until 1991, but what you have now is a 2 piece hydraulic flat tappet engine. 85 has some tuning quirks and the EGR setup is a little different than 86+ but its nothing that should scare you away. You can swap over your current intake if you so choose.
