85 ecm ground
Old Mar 9, 2015 | 07:41 PM
skip myles's Avatar
skip myles
Default 85 ecm ground
i have an 85 low milage vett seem to have trouble with tps having changing volt readings it is new set it at .54 car runs great after a few trips it idles high have to reset tps runs good again then seems to change was told a bad ground to ecm would do this
Old Mar 10, 2015 | 01:44 AM
Cliff Harris's Avatar
Cliff Harris
Check the ground connections on the driver's side of the block above the oil filter (G104):
