headlights stuck on bright
Old Mar 10, 2015 | 07:38 PM
antfarmer2's Avatar
antfarmer2
Default headlights stuck on bright
Headlights stuck on bright along with the blue light on the dash but foglights work fine any ideas where to look and how to fix thank you in advance
Old Mar 10, 2015 | 07:49 PM
antfarmer2's Avatar
antfarmer2
Old Mar 10, 2015 | 09:11 PM
gdl2165's Avatar
gdl2165
What kind of headlights are you using? If you've switched to LED or HID, it'll cause an issue whenever you turn the fog lights on, it'll force the high beams on. Try turning the fogs off and see if the headlights go back to normal.
Old Mar 10, 2015 | 09:24 PM
antfarmer2's Avatar
antfarmer2
I put in cibes and was working fine for months but took your advice and tryed it works great now thank you so much cheap and easy
To headlights stuck on bright
