open vs closed mode.
Old Aug 10, 2002 | 05:55 PM
devilfish's Avatar
devilfish
Default open vs closed mode.
When does the car goes in open vs closed mode?
And what could be wrong if the car runs great when you just started it after a night in the garage, but when it gets hot it runs much worse, power loss? False knocks? Bad MAP censor?
Regards
Old Aug 10, 2002 | 06:30 PM
vader86's Avatar
vader86
Default Re: open vs closed mode. (devilfish)
the car goes into closed loop as soon as it gets up to temperature (like 160), it starts in open loop
Old Aug 10, 2002 | 06:40 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Upon start up ECM will go closed loop when the following all have occured:
1) a preset amount of time has elapsed
2) coolant temp reaches prescribed level
3) the O2 sensor is responding properly
It will then go into open loop (reading but ignoring O2 sensor data) when it senses the WOT condition.
When you first start up the engine is cold and you have a rich condition. Mine also has most power under this condition.
To reduce knock by lower engine temp, proper octane fuel, correct ignition timing.
I believe that a failed MAP, like a failed MAF, should throw a code. Though when my MAF failed it didn't throw a code the engine just wouldn't run.
Old Aug 10, 2002 | 06:48 PM
bill mcdonald's Avatar
bill mcdonald
What is your car doing exactly?
Does it run okay when hot adn you go to wide open throttle?
Old Aug 11, 2002 | 03:12 AM
devilfish's Avatar
devilfish
Default Re: open vs closed mode. (bill mcdonald)
well I know that car always goes better when its cold. But when my car gets hot the SOTP feel is alot less. Its like i loose 50 hp. :/
Old Aug 11, 2002 | 03:15 AM
vader86's Avatar
vader86
Sounds like you might have a bad O2 sensor.
Old Aug 11, 2002 | 01:41 PM
devilfish's Avatar
devilfish
Default Re: open vs closed mode. (vader86)
ok. Can i try to run the car without it to se if that helps?
REgards
Old Aug 11, 2002 | 06:21 PM
devilfish's Avatar
devilfish
tt
Old Aug 11, 2002 | 06:22 PM
vader86's Avatar
vader86
I'm not sure about the sensor stuff, but i dont think it will even run w/o an O2 sensor sending signals back to the ECM.
Old Aug 11, 2002 | 06:28 PM
devilfish's Avatar
devilfish
k.. Cant figure it out.. :rolleyes: Can I check the 02 censor in anyway?
Old Aug 11, 2002 | 06:51 PM
ALLR RED's Avatar
ALLR RED
How about partially stuffed cat. or cats. ?
Old Aug 12, 2002 | 06:07 AM
devilfish's Avatar
devilfish
Default Re: open vs closed mode. (ALLR RED)
my pre cats are gut. I dont know the condition of my main cat, but wount that hurt prefomance when the engine is cold also?
Old Aug 12, 2002 | 09:41 AM
ALLR RED's Avatar
ALLR RED
Generally a bad cat won't show up until it's hot as you described. I have run into bad cats. many many times, and the cars all acted just like you have desribed. Just an educated guess though :)
Old Aug 12, 2002 | 11:15 AM
devilfish's Avatar
devilfish
yeah, its like the engine just make more noise but the car dont move any faster :/
[Modified by devilfish, 4:16 PM 8/12/2002]
To open vs closed mode.
