Knock censor location?
Old Mar 14, 2015 | 02:53 AM
Bangkok Dean's Avatar
Bangkok Dean
Default Knock censor location?
Where is the Knock censor on 90-91 L98 located?
Old Mar 14, 2015 | 03:17 AM
WVZR-1's Avatar
WVZR-1
Right side engine block front of starter
Have you gotten your run situation pretty much under control?
Old Mar 14, 2015 | 11:29 PM
Bangkok Dean
Thanks for the location for the Knock censor.
No I still am having problems with high fluctuating idle. At this time I am looking really hard at a carburetor set up.
But I am waiting for a cable to connect my laptop using a program suggested by Scott Hanson.
There no scanners here that I know of so finding what the problem is will take a program to read what the hell is going on.
Getting the cable sent here takes time and $$$
But with the help from forum members I will get this sorted.
Old Mar 15, 2015 | 12:29 AM
antfarmer2's Avatar
antfarmer2
Spend a bit of time there never saw a corvette the tuk tuks must try to run over your hood lol if you don't get one maybe I can help will be there after it cools off
Old Mar 15, 2015 | 12:30 AM
antfarmer2's Avatar
antfarmer2
I would look at your vacume lines
Old Mar 15, 2015 | 04:14 AM
Bangkok Dean
I have looked but I am unable to hear any leaks, I wish they sold a propane torch here, so I am waiting for the cable in order to see what the computer says. If there is a vacuum leak I hope the scanning program will tell me?
BTW, what does the knock censor do and what does it measure?
Old Mar 15, 2015 | 08:09 PM
Cliff Harris's Avatar
Cliff Harris
The knock sensor is basically a microphone that is tuned to certain frequencies. It listens for knocks (pre-ignition or detonation), which is usually caused by things like too low octane fuel, too much spark advance, heavy load and things like that.
When the knock sensor detects knocks, the ESC (Electronic Spark Control) module sends a signal to the ECM. The ECM assumes there is too much spark advance for the current conditions and retards the spark. On my car it retards by 6°. Other years might be different.
Old Mar 15, 2015 | 09:10 PM
Bangkok Dean
Interesting, thanks..
To Knock censor location?
