Large amp draw when car off
Old Mar 22, 2015 | 04:02 PM
  #101
P944's Avatar
P944
1st Gear
Maybe buying a DC-clamp amp meter is an idea .
I have one with a 1 " clamp.
Is 0,1 amp accurate.
Old Mar 22, 2015 | 04:09 PM
  #102
crowz's Avatar
crowz
Ive never had much luke getting good dc readings with a clamp meter under 10 amps draw. But things may of changed over the years.
Old Mar 23, 2015 | 08:05 AM
  #103
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I have had this one for a few years and really like it. Bought it solely for low amp clamp readings, which is great for searching for current draws.
Sure it's much cheaper in the US.
General Technologies Corp. CM100 1 mA to 100 Amp AC/DC Low Current Clamp Meter: Amazon.ca: Automotive General Technologies Corp. CM100 1 mA to 100 Amp AC/DC Low Current Clamp Meter: Amazon.ca: Automotive
Old Mar 23, 2015 | 03:51 PM
  #104
Z51BOB's Avatar
Z51BOB
Cruise-In II Veteran
Default Regarding the amp draw.
1) I thought those clamp on meters only work on AC
2) Went through this on my '90 & found a wet fan relay - It rusted internally and provided a path directly from the Battery side to the coil side. Looked fine on the outside but was slightly warm.... Are you sure you unplugged all of the relays under the hood during your test?
Old Mar 23, 2015 | 04:12 PM
  #105
crowz's Avatar
crowz
There are a bazillion of them so sure I could of missed something but I do know for sure I did the following :
Headlights
Fuel pump
Mass air flow (both relays)
aux fan
main fan
a/c connections at firewall and compressor
ignition related items
wiper motor
tps (figured what the heck while I was there)
I did more than that but that's what I remember clearly targeting.
Just got my wifes Mercedes 190d turbo pulled out to start restoring it. My works never done it seems.
Anyways after I put the battery charger on the Mercedes I will be doing the fuse panel both sides per fuse test so will have those results in a few minutes barring relatives, weather, pets or who knows what else getting dumped on my plate.
Old Mar 23, 2015 | 05:56 PM
  #106
crowz's Avatar
crowz
Ok got some testing done.
All fuses removed and testing both sides of the fuses.
There were 2 on the bottom that had no power either side. Will look into that later.
The curious one was the courtesy/clock fuse. 12 volts one side and .2 to .4 volts other side. Key on or off.
All other fuses 12volts on feed nothing on the other side key on.
Key off everything was as expected 12 volts where appropriate and nothing were it shouldn't be. Still the courtesy/clk fuse showing .2 to .4 volts on the side that should be dead. Rain odds to high to remove dash pad and go after the courtesy module today.
Weather looks more promising tomorrow.
Old Mar 23, 2015 | 09:22 PM
  #107
playsdixie's Avatar
playsdixie
you can chase your tail with the cts/ck circuit....it has the memory for the stereo/seat/clock/timer, not sure how it all works, I'm somebody will straighten me out, but I know putting your meter in series with the + post and battery initiates the battery draw....it should time off...also, my 85 has a spare tire light on that circuit....good hunting...
Old Mar 24, 2015 | 12:16 AM
  #108
Cliff Harris's Avatar
Cliff Harris
That fuse supplies power to a zillion places. Basically everything that is powered when the ignition is off. That would be interior lights, under hood lights, radio memory, C68 HVAC system memory, cigarette lighter, center console compartment light and more...
Old Mar 24, 2015 | 05:18 AM
  #109
Blue Vert 91's Avatar
Blue Vert 91
slightly warm, this just gave me an idea, I know you are using a meter to look at the car to find the amp draw, have you considered looking at the car with infra red to see if something is warm? we use them in the firehouse to look for heat? perhaps someone has a camera to borrow?
or rent? http://www6.homedepot.com/tool-truck...amera/FLIR_i7/
Old Mar 24, 2015 | 11:03 AM
  #110
crowz's Avatar
crowz
Cool idea but nope not available to rent in my area
Old Mar 25, 2015 | 02:06 PM
  #111
crowz's Avatar
crowz
Good news I found the courtesy module !
Upside down and laying in the seat with my head in the floor I actually saw it.
Had to come up for air so to speak after finding it. Now to get back under there and unplug it and wire the white and black wires together thus bypassing it.
Going to do a amp draw test as soon as I get it unplugged and before messing with the wires.
Old Mar 25, 2015 | 02:28 PM
  #112
crowz's Avatar
crowz
Module unplugged and no change to amp draw
Proceeding to wiring bypass to do away with the courtesy module which is bad.
Old Mar 25, 2015 | 03:05 PM
  #113
crowz's Avatar
crowz
Well that didn't fix the draining problem but I now have interior lights when I open the doors and the switches on the doors will pop the cover for the convertible top again now.
Worth it.
But still tracking drain issue.
Old Mar 25, 2015 | 03:34 PM
  #114
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
Worth it.
did u replace the ctsy module or fix the module? how did u get everything to work again?
keep going on the draw.
Old Mar 25, 2015 | 03:43 PM
  #115
crowz's Avatar
crowz
I unplugged the module and ditched it.
Then I spliced the one white wire in the 'a' spot on the connecter to the 2 white wires in the 'd' spot of the connector.
So you connect all 3 white wires together on an 87 model to bypass the module with the module removed completely.
I took pics of the location and wires done just need to get them off my phone.
Old Mar 28, 2015 | 04:46 PM
  #116
phat87's Avatar
phat87
2021 C4 of the Year - Unmodified Finalist
Default 10-4
still following this. Good luck.
Old Mar 28, 2015 | 06:07 PM
  #117
crowz's Avatar
crowz
Spent the last couple of days installing stereo and driving the car some.
Weather went from 77 to 40 and less since yesterday so Im hibernating till the weather warms back up which should be first of the week. I will be removing the wires from the distribution point behind the battery again but this time pulling all fuses and relays to try to find which one has the load.
To Large amp draw when car off
Old Mar 30, 2015 | 12:16 PM
  #118
crowz's Avatar
crowz
Got more emails this morning asking me if Im still working on this and I still am. Its pouring rain outside right now
So no I haven't forgotten this one.
Old Mar 30, 2015 | 12:18 PM
  #119
crowz's Avatar
crowz
Oh and I know it was mentioned earlier in this thread about the power antenna and I basically dismissed it as being taking out by the fuses etc but I noticed it sure sounds like there is a noise from that area when I turn the battery disconnect **** powering the car back up. There is something making a noise for about 1 second from that area. All I can figure is the fuel pump or power antenna from back that way. Will investigate that some too when the rain stops.
Old Mar 31, 2015 | 10:50 PM
  #120
phat87's Avatar
phat87
Default rain
Rain is a bummer! Very hard to get motivated when there ain't no Sun. Many people here are pullin' for ya, and dyeing to know the out come.
You are the embodiment of tenacity!
