96 LT1 w/auto trans. Leaking around the speed sensor, on the
back part of the transmission.
Question should I just change the sensor and 0 ring or just the 0 ring.
Speedometer works fine, but since I am going to be under there - well
you know, just do it right the first time.
tks Putz
If everything works and it's not leaking through the connector I'd just do the seal. Now you need to be cautious I'd guess that you don't destroy the VSS removing it. For that style of VSS there's a specialty VSS removing tool. It works very well. I do have one.
