C-4 Tires
285/40ZR17's and 255/45 /ZR 17's
Have about 1,300 miles on them now and still like the change. Finally got rid of the original Goodyears. The rear Goodyears made a lot of noise even though I still had a lot of good tread left on them.
Not sure if they come in your sizes, mine are 275X40X17 all around.
Mick
change to 275/40/17 then you have more choices....like Nitto NT05
Kumho makes a nice looking tire as well. Vredestein also makes a nice looking tire as well. Falken as well.
This is the tread design on the NT555. I was wanting something with an interesting tread as well. I ended up with this model as they had exact sizing which I decided I wanted in the end.
Russell
I haven't tried C6 wheels on my 1996 (was that your REAL question?), but look through EBay at the wheels offered there. Usually some charts/comments on what fits what.
For 17" tires, I ran Sumitomo tires - 275/40/17 and 315/35/17 - on my 9.5 and 11 wide rims. Their 'summer performance' (HTR-Z, I think they call them) tires handled pretty good, the price was VERY good, and they are still available.
Good luck.
walt z.
http://www.discounttiredirect.com/di...5&rd=17&cs=255
http://www.discounttiredirect.com/di...0&rd=17&cs=285
Good luck.
walt z.
My vette is being drag raced as well as road summer driving.
Where did you find the Sumitoma tires.
Gary
I got them on EBay from 'Big O Tires' out of Florida. That was several years ago, but there are other dealers that have them now. Around 600-650 for the set of 4. The tires are better 'drivers' than 'drag race' tires. I used them for autocross and they handled pretty good (Treadwear rating of 160).
Good luck,
walt z.
Good luck.
walt z.
The only negative thing I have found is the 315's have a tendency to wear faster than the fronts oddly enough. I dont do any burn outs either. When the first set of 315's wore out, I thought the PO maybe burnt them off cuz the fronts still had 1/2 tread. I just replaced the fronts after 6 years and 40K miles and looked at the rears and it seems like I will be replacing them pretty quick again.I bought mine from TireRack.
Good luck.
walt z.
Some have complained they don't give as sharp as turn-in, but so far, they feel just about the same to me as far as handling is concerned. Also MUCH quieter than the Goodyears.
I got a set of four in OEM size from an online company in Canada for just under $1000 Canadian, including our 13% sales tax and delivery to my door ....that's about $825 US at today's exchange rate.
I am still amazed that the delivery charge was only $5 -- seriously: five dollars to deliver by courier.
Only point I disagree with is the turn in sharpness. These DW's don't have the same edgy feel. I *think* its because sidewall softness as compared to the run flat OEMs I had.
Another point about them.. they are about the lightest tire you can buy. And that helps in all ways.
Getting back to your C6 wheel question.
I just purchased a set of C6 Spoke Wheels for my C4 Roadster, specs are
Part numbers
9594346 Front 8.5 in x 18 in x 56 mm
9594346 Rear 10 in x 19 in x 79 mm
You can Google for Photos. These are Factory painted Corvette Wheels, I am going to remove the Paint and Polish all four wheels.
Hopefully this weekend I will have the tie to Bare mount the wheels (W/O tires) so I can check for any clearance issues and measure the both the front and rear wheel track width.
Once I have done the above I will decide on the size(s) I'm currently running Good Year P275x40x17 HP up front and P285x40x17 HP in the rear, and have no clearance issues on 17 x 9 1/5 inch Vette Wheels. I have NOT as yet compared the offset(s) between the two wheels, ie the wheels on my C4 and the C6 wheels.
I'll let you know the result as soon as I have finished mounting the wheel and have the numbers.
Let me know if there is other info you'd like to obtain,,,
Michael....
NOTE: guys, you should know that the crappiest new tires you just put on ALWAYS feel better than the best WORN-OUT tires that just came OFF your car. That's a fact...
